MSD 6AL with HEI??
I have a brand new MSD 6AL that was under the seat of my truck when I bought it. Not hooked up, wired, nothing....
Curious if these can be installed with HEI? Any Benifits? I thought these had to be hooked to pos/neg on the coil and direct to pickup? Any help is MUCH appreciated!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
Still Just Havin Some Fun!
![]() Join Date: Jun 2007
Re: MSD 6AL with HEI??
you can run them with HEI. The 6AL is a great box and offers many perks to running. Go to the MSD site and they will have directions. Follow them or you will have a no good MSD6AL.
a green one with some stuff done to it.... |
you basically gut the hei out use the two wires from pickup to the box and wire the coil into the box it works great starts easier and you have a rev limiter
#4 | |
Yes. You buy an external coil and a piece that replaces the HEI coil. Check MSD. They have all the pieces. Mine works great.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
no the coil will stay there the msd will replace the internals forgot whats its called just google msd 6al wiring diagram and you will get it it's pretty simple to do
I had to use an external coil when I did mine. Maybe they've come up with some other kit.
![]() Join Date: Feb 2011
I just talked to the tech support this morning about installing a 6A. Follow the instructions for GM four pin module.
http://www.msdignition.com/uploadedF...structions.pdf
1971 C20 Longhorn Custom Camper |
Stock coil, simple to do really
loads of times installs of those boxes are quite shody and screw the whole ignintion system up
not really any great advantage on a daily driver street machine but more of a potential source of being stranded on the side of the road
For a stock to mild set up you will not see any improvement over your stock HEI. Just my humble opinion.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I had an MSD on my Jeep back in the 80's. It starter running poorly one day and I thought the MSD failed. Come to find out about a month ago it just burned the coil. My buddy at work checked it out and said it works fine......could probably weld with it! I'm gonna try it out on our 68 with I6. He also told me to use a coil with the lowest resistance possible. Besides, if it starts running rough, more than likely gonna be the coil that that failed (easy enough to reverse until I get a new coil).
#13 | |
I do think the 6AL made a great improvement on my truck, which is a weekend driver, but it's fairly radical. Good installation is always key.
#14 | |
#15 |
![]() Join Date: Jan 2001
HEI over an MSD any day on a stock-ish setup. I regret putting one on my 402 but I had to because I needed the clean tach signal for my EFI otherwise I'd never have changed it.
Bud |
#16 |
I had a stock HEI on a 350 with a long overlap cam in my 65 Malibu. Barely got enough vacuum to run the power brakes. I put the MSD box on, just using the pickup from the HEI to send a signal to the box. Kept the stock coil on top of the HEI, but as I recall MSD tells ya to replace the carbon button that connects the coil to the rotor as it tends to burn out. Did all that and got a much better running motor and 2 more inches of vacuum.
Planning to do the exact same thing on my 69 C10, HEI with an MSD box. IMHO and experience, the hotter, and multiple spark helps when running a bit of a hot cam on a vehicle used on the street. |
