03-08-2011, 11:26 PM | #1 |
Polyurethane Bushing Question
I'm replacing my rear control arm bushings with polyurethane bushings. The photo below shows the bushings but they came two slide washers that cap over the skinny end.
I've got the bushing in but noticed that even with the bushing pressed all the way in, it's too wide to squeeze back into the mount with the slide washer on. Should I try triming down the slide washers or just not use them? Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 03-08-2011 at 11:29 PM. |
03-08-2011, 11:43 PM | #2 |
Moderator
Re: Polyurethane Bushing Question
They are a tight fit. Try prying the mounting prongs (cant think of a better word for them) apart slightly and squeeze the arms in. Worked for me.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-09-2011, 02:18 PM | #3 | |
Thanks!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
