Old 03-09-2011, 08:04 PM   #1
Constructor1
Bent Sway Bar
I was under my truck and noticed that my sway bar looks bent. Are they designed to have the bend in them, or is this damaged? It appears that if the bar were straight, it would be to long. Maybe one of you fine folks can tell me if this looks right to you.
Constructor1 is offline   Reply With Quote
Old 03-09-2011, 08:22 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bent Sway Bar
That is BENT!
It's not a sway bar it's the panhard bar/track bar that keeps the rearend "centered" under the truck.
I would take some measurements and see if the brake backing plates are the same distancefrom each frame rail.
Keith
Convert to disc brakes.
Old 03-09-2011, 08:23 PM   #3
eagleuh1
eagleuh1's Avatar
Re: Bent Sway Bar
Thats not your sway bar. Thats the panhard bar. Are your wheels centered side to side. It looks like they would be pulled to the drivers side if bent.
eagleuh1 is offline   Reply With Quote
Old 03-09-2011, 08:24 PM   #4
lolife99
lolife99's Avatar
Re: Bent Sway Bar
I'm not sure if you want to try to straighten it or not.
I probably have a stock one you can have,... if you can't find one locally.
Keith
Old 03-09-2011, 08:29 PM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Bent Sway Bar
Very generous lolife!
And, yup. Pretty bent.
ETsC10 is offline   Reply With Quote
Old 03-09-2011, 08:42 PM   #6
lolife99
lolife99's Avatar
Re: Bent Sway Bar
Just for a reference point.
A stock track bar should be 24" center-to-center.
(or 25-3/8" overall length)
Keith
Old 03-09-2011, 09:31 PM   #7
dave2953
Dave's not here, man
dave2953's Avatar
Re: Bent Sway Bar
Wow! How did that happen? I've never seen one bent before, let alone bent like that.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-09-2011, 09:49 PM   #8
Constructor1
Re: Bent Sway Bar
Thanks for the replies. I am pretty sure it was like this from previous owner as all driving I have done has been fairly gentle.
I will take some measurements tomorrow. What is worst case damage this would cause driving the truck with the bar bent like this. I have probably put 500 miles on truck since I bought it.
Old 03-09-2011, 10:06 PM   #9
Constructor1
Re: Bent Sway Bar
I went ahead and went out in the dark and crawled under the truck to measure. From bolt to bolt is 24" so That will make the bar much longer than that. Rough measurement in the dark with stiff tape was around 26". Could this be from another vehicle and the PO bent to make fit?
My measurements from back of brake drum to frame were 12" driver side and 11" passenger.
lolife99 - thanks for the offer. I will see if I can find one locally and then go from there.
Old 03-09-2011, 10:10 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Bent Sway Bar
Does your truck have any drop? If it does, PO may have done that to "get by"
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-09-2011, 10:17 PM   #11
lolife99
lolife99's Avatar
Re: Bent Sway Bar
Didn't the earlier trucks (60-6?) have a longer track bar that connected to a mount on the passenger side axle tube?
Also,... have the rear springs been heated?
Idealy,... you want the rearend centered,... whether its at stock height or lowered.
If it's lowered you might need to purchase an adjustable track bar to bring the rearend back to center.
Like it is now,... I would think the truck would "dog track" down the road.
Keith
Old 03-09-2011, 10:27 PM   #12
Constructor1
Re: Bent Sway Bar
I am unsure if it has a drop. It appears to be sitting low in the rear - or level with front, but not sure what PO may have done. It seems to drive just fine, no uneven wear on tires or strange movements that I can tell.
Old 03-09-2011, 10:48 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Bent Sway Bar
PO could've heated the springs..
If you need a 67-72 24" bar, Ive gotta extra one you can have if needed (Was sent to me free when I needed one). Let me know
John
1999 Toyota Tacoma 4x4
