Old 03-19-2003, 09:51 AM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Steering Column Rebuild
Does anyone have a step-by-step guide to rebuilding a tilt column?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 03-19-2003, 01:47 PM   #2
Class of 69
Class of 69's Avatar
Rebuild tilt
You're not getting much help on this. Really surprizing(have no idea how to spell that word!) for the amount of activity on this board. I looked through my service, and overhaul books, and the only column it covers is the non-tilt procedure. I can only guess that it was originally covered in a supplement. I recommend contacting Bishko Books in Ohio. When I couldn't find an overhaul manual, I found them on the web. They buy, and sell original manuals, and had the one I got in stock. Original 68 printed book, in perfect condition for $44.00 to my door!! They may know if there is a supplement available for the tilt columns. www.autobooksbishko.com Good Luck
Class of 69 is offline   Reply With Quote
