Old 03-10-2011, 02:26 AM   #1
Zonaman
Zonaman's Avatar
Unorthadox Traling Arm Removal
When I decided to replace the trailing arm bushings on my C-10, I planned to remove the arms so I could work on them on my bench. Eveything came off OK till I got to the U-bolts on the axle. My air wrench wouldn't budge them. Tried heating them- no good. Got a breaker bar with long pipe on it- you can see the result below. I didn't have a bolt splitter and I didn't want to cut the u-bolts so I just lowered the axle on a couple of jacks. The inner sleeves and old rubber pressed right out- clean! A little tricky lining everything up but no real trouble. I'm wondering- How many others have done it this way?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 03-10-2011, 02:45 AM   #2
darush01
Re: Unorthadox Traling Arm Removal
I had to cut my u bolts and have yet to get the things off
darush01 is offline   Reply With Quote
Old 03-10-2011, 02:49 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
You can easily remove the u-bolts by using a cut off wheel on an angle grinder. I've snapped off the bolts before when trying to break them free in the junk yard. If I had a grinder that I could use in the junk yard that would have been my first choice, but you gotta make do with what ya got.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-10-2011, 03:01 AM   #4
leddzepp
Moderator
leddzepp's Avatar
I had to burn out the old bushings with a torch...they were stuck in there for life. Removing the U-bolts on the trailing arms was easy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-10-2011, 09:39 AM   #5
ubtripn
ubtripn's Avatar
Now keep that wrench under your front seat, it still has uses.
Creative solution by the way!
ubtripn is offline   Reply With Quote
Old 03-10-2011, 10:56 AM   #6
Zonaman
Zonaman's Avatar
You mean like a boomerang?
Old 03-10-2011, 12:20 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
How did you press out the bushings ?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-10-2011, 12:39 PM   #8
ubtripn
ubtripn's Avatar
More like that steering wheel lock convieniently caled, "The club."
Old 03-10-2011, 12:48 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Dang, I feel cheated. Mine came out of the crossmember w/o any issues. The biggest problem was getting the coil spring retainer loose. One galled nut really messed with us, but we didn't let it take us down.
I think it was the fact that we had the rear end out and turned upside down that let us get serious with it.....
....waitin' on the sandblaster to call and say he's done..
Member Nr. 2770
Old 03-10-2011, 04:43 PM   #10
smallblockchev
I would just cut the ubolts off. They are cheap and most auto stores should have them.
2007 Chevy 2500HD all stock
1985 Chevy Blazer- sold
1971 Chevy c10- The Mistress
2014 Ford Interceptor SUV
smallblockchev is offline   Reply With Quote
Old 03-10-2011, 07:56 PM   #11
eagleuh1
eagleuh1's Avatar
Get some PB Blaster and soak them the day before after wire brushing around the u-bolts and nuts. Soak them again a couple of hours ahead of time. This has worked on all but one of my bolts on my truck. The tailgate pivot bolt on bottom snapped while trying to work back and forth. If that don't work, they probably aint worth saving anyways.
eagleuh1 is offline   Reply With Quote
Old 03-10-2011, 08:47 PM   #12
Jacfourteen
Agreed!
Old 03-10-2011, 09:32 PM   #13
cparman
sharp as a marble
Looks like you have the nuts off already? I had the same problem on my 69. I put the nuts back on several threads. heated the control arm red hot, and with a BFH drove the ubolts out. Thinking back, I would/should have cut the ubolts off and junked them along with the control arms.
cparman is offline   Reply With Quote
Old 03-10-2011, 11:18 PM   #14
Zonaman
Zonaman's Avatar
I just needed the inner sleeve and the rubber out (polyurethane replacments). I used a 3 jaw puller with a socket over the screw. Insead of pulling it was pushing. It's real dry in Arizona and, as I suspected, that 40 year old rubber wouldn't give me too much trouble. In fact, it came out clean on both bushings. That rubber was dried out like a rasin! I thought I might need to wire brush off some from the sleeve but it was bare metal in there.
If I was going to remove the outter sleeve, I would surely have cut the bolts because there's no decent way to press them out from undneath. I didn't have a car that day but figured I could get it done this way instead of waiting till the next day to go hunting for u-bolts. It worked but I don't think too many folks ever do it that way.
What's PB Blaster? Sounds like good stuff.
Old 03-11-2011, 03:09 AM   #15
Sicklajoie
The Niner
Sicklajoie's Avatar
Amazon.com: Blaster 16-PB Penetrating Catalyst -... Amazon.com: Blaster 16-PB Penetrating Catalyst -...
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-11-2011, 07:22 AM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can buy PB Blaster at any Walmart or O Reilly.
