03-10-2011, 10:05 AM | #1 |
removing bed panels
How do I remove the rear bed panels from my fleetside?? Can't find a description...thanks.
03-10-2011, 10:30 AM | #2 |
Re: removing bed panels
Take lots of pictures, then work away. Theres a drawing of a bed all apart on the LMC site and Mar-k.
03-10-2011, 11:18 AM | #3 |
1961 crewcab
Its a ton of work, but, you take all the bolts off on the inside edge of the bed/holding the wood.
under the wheel well there are bolts holding the tub to the bed. there are blts holding the front to the front bed panel there are 4 bolts holding it to the rear cross sill, underneth. take the tailgate off, and in the corner under the t/g trunion there are 2 factory weld beads that need to be cut, I use a angle grinder with a big disk to reach, but have had luck with a chisel, or a hacksaw in a pinch.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
