It'd be alot cooler if you did
Custom fuel cell
Alright guys I'm going to have a fuel cell built problem is I dont know what exactly I want. I want it mounted under the bed floor, I cant put it in the back behind the axle as my exhaust is in the way, I could put it above the frame, just not between the rails. I plan on raising the floor about 3-4". Ideas? pretty much have to put it either in front of or behind the axle between the rails on top of the frame but under the raised floor.
Re: Custom fuel cell
do you guys think it matters weather or not I make it wider than the frame rails??
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
that might make for a wierd tank, why not move the exhaust? like dump it in front of the rear axle? then you can call Boyds and get one of their aluminum tanks.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
not moving the exhaust. I do not like dumps.
OK, maybe someone has another option. if you can think it and draw something, boyds can make it too.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 03-10-2011 at 05:53 PM. |
Square
based on this picture
![]() I would say a cool spot might be like a 10 gallon tank on the inside of the frame between the axle and that crossmember, like opposite of the 4 link?
Squarebody Syndicate |
