Big Red - Now its a SWB!
I was in the middle of an oil change on my 01 Tahoe out in the driveway this morning, when it started pouring rain (and the weather man said "no appreciable rain"
![]() Here is from a stop, I spun in all 4 gears. Its hard to tell when I shift, but you can see the change in MPH on the speedo. You can see when it starts shaking from the carrier bearing I have to let off the gas. ![]() Here is a 45MPH roll in 4th gear, when I hit the gas it got the tires spinning to about 75-80 but I never sped up. ![]()
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Re: Fun in the rain
Next time it rains I'll have to get some better vids with my video camera out on open road. Maybe I'll have the 12 bolt swapped in by then.
the boat guy
Re: Fun in the rain
when you get your carrier bearing replaced be sure to have your driveshaft ballanced.
Re: Fun in the rain
Thanks for the tip, I didn't realize you had to re-balance after a carrier swap. I might be ditching the driveline altogether because the reason the carrier went out is the splines on the slipshaft are messed up and it slides really tight, so when the axle moves up/down it put stress on the carrier. I am about to swap out rears from a D60 to a 12 bolt so I will address the driveline then.
