Rivets
Does anyone know a good place I can order rivets for a 70 c10 Grille? What size would I need? All info appreciated...Dave
Between Trucks...
Re: Rivets
I used pop rivets from the hardware store.
Beat it to fit, Paint it to match... ![]() |
Re: Rivets
x2 on that statement
Fuzzy |
![]() Join Date: May 2007
Re: Rivets
beyond what the others have said check with most any of the board vendors they sell a grill hardware kit
The Older Generation
Re: Rivets
If you use pop rivets make sure they are aluminum not steel... ![]() LockDoc
Re: Rivets
Thanks Everyone.. Dave
1969 Custom 30 wrecker
Re: Rivets
I like the type that have a theaded shaft and nut. From the top they look like an original rivet but you can easily remove them and reinstall anytime if you had to. Pop rivets will have a hole on the top.
Lots of vendors sell them.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 Last edited by bobs409; 03-11-2011 at 08:18 AM. |
Re: Rivets
i've found original type rivets at my local fastener store// i guess around here they are commonly used on aluminum screen enclosures and rooms
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Rivets
I had a kit around here that I bought from wes at classic heartbeat but cant seem to find it right now..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
