gauges for a lq4
I put a lq4 in my truck and was wanting to use the factory sensors and leads from the ecm to run the gauges. I want to use aftermarket gauges, what gauges can I use?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
Re: gauges for a lq4
You really can't use the factory sensors for anything but the factory LQ4 gauges. If you're going to use aftermarket gauges, they should come with their own senders.
69' Chevy Stepside
![]() Join Date: Mar 2008
You can use the LQ4 speed output on the transmission, the coolant temp (on mine at least some can't) and possibility the oil pressure sender but that might not be very accurate...
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#4 | |
Posted via Mobile Device |
