Old 03-11-2011, 12:06 AM   #1
jojoman
will this work
i got a 87 no tbi just carb will this intake work on it or no if not what should i go withhttp://www.summitracing.com/parts/EDL-7501 thanks and what wires and plugs are you running
jojoman is offline   Reply With Quote
Old 03-11-2011, 12:11 AM   #2
texasbigbear_wink
texasbigbear_wink's Avatar
Re: will this work
Yep It should work. I run AC Delco plugs they work the best on chevy's do nut run bosh they are crap. Plug wires well just depends on what all mods you are doing.
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 03-11-2011, 12:18 AM   #3
jojoman
Re: will this work
i just got everything stock i think has a mild cam headers that pretty much it so it should work then huh
Old 03-11-2011, 12:38 AM   #4
texasbigbear_wink
Re: will this work
It should but there are guys on here allot smarter than me and if I was you I would wait on a second opinion before making any purchases.
87 Chevy R10 LB
Old 03-11-2011, 12:39 AM   #5
jojoman
Re: will this work
im going with this i think it should be good http://www.summitracing.com/parts/EDL-2604/
Old 03-11-2011, 12:48 AM   #6
texasbigbear_wink
Re: will this work
Yep
http://s1210.photobucket.com/albums/...exasbigbear21/
87 Chevy R10 LB
Old 03-11-2011, 08:23 PM   #7
jojoman
Re: will this work
where did you find those valve covers
Old 03-11-2011, 08:32 PM   #8
texasbigbear_wink
Re: will this work
http://www.summitracing.com/parts/SUM-G3309/
They are heavy duty to. The pic's of them on are on the photobucket link now.
87 Chevy R10 LB
Old 03-11-2011, 08:47 PM   #9
jojoman
Re: will this work
you suggest buying new bolts or no if so which ones should i buy
Old 03-11-2011, 10:19 PM   #10
texasbigbear_wink
Re: will this work
This is the ones I got and yes if your are going with chrome valve covers than I would get these chrome blots.
http://www.summitracing.com/parts/TRD-9812/
87 Chevy R10 LB
Old 03-11-2011, 10:37 PM   #11
joe231
joe231's Avatar
Re: will this work
Jojoman,
What heads do you have?
CHEVY ONLY
Old 03-13-2011, 08:14 PM   #12
jojoman
Re: will this work
i got tbi heads on carb no tbibut i seen this thing about 23 degree heads i dont know what those are i dont think i got those i called this place here and they told me a air gap intake wouldnt be good for my motor since it idle high that what they said
Old 03-13-2011, 09:14 PM   #13
joe231
joe231's Avatar
Re: will this work
If you have TBI heads, you should have center bolt valve covers and the 2 center intake bolt holes are drilled at a different angle than older carb heads.
CHEVY ONLY
Old 03-13-2011, 09:31 PM   #14
jojoman
Re: will this work
yea they drilled straight down instead of being angled i believe so what do you recommend
Old 03-13-2011, 09:59 PM   #15
joe231
joe231's Avatar
Re: will this work
You will either need an intake to fit the TBI heads or you will need to modify a standard intake. What intake do you have now?
CHEVY ONLY
Old 03-13-2011, 10:01 PM   #16
jojoman
Re: will this work
which one do you guys recommend motor just stock mild cam headers right now has single plane intake http://www.summitracing.com/search/D.../?Ns=Price|Asc
Old 03-13-2011, 10:53 PM   #17
mooseknuckles
mooseknuckles's Avatar
Re: will this work
edelbrock performer
mooseknuckles is offline   Reply With Quote
