Old 03-11-2011, 12:57 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Cunifer brake/fuel line kit (Easy to bend and flare and don't rust)
Fedhill USA Brake line kit. Brake lines are cunifer which makes them easier to bend and flare than std lines. Comes with assorted fittings. New never used
Runs 123 plus shipping from Fedhill but currently out of stock (see link)
http://store.fedhillusa.com/t4.aspx
In stock 1 set from me to you Asking 120 shipped.
1 coil of 3/16"/4.75mm OD tubing x 25 foot, 1/2 coil of 1/4" OD tubing x 12 foot and a #2 and #4 nut pack
#2 Nut Pack:
10 ea A1-3
4 ea A1L-3
1 ea UA1-3
2 ea A12-3
2 ea A13-3
1 ea A14-3
#4 Nut Pack:
10 ea A2-4
6 ea A2L-4
1 ea UA2-4
1 ea A23-4
1 ea A24-4
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-11-2011, 12:59 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Cunifer brake line kit (Easy to bend and flare and don't rust)
Info about cunifer for those that aren't familiar (I wasn't until I read about it)
Cunifer is a seamless, copper nickel alloy DOT approved brake line used for OEM and replacement brake lines, fuel lines, power steering and cooling lines. Corrosion proof and easy to install high pressure hydraulic tubing for the harshest environments. All of our tubing conforms to hydraulic brake tubing specifications SAE J1650, DIN 74234 and BS 2871.
Old 03-11-2011, 01:23 AM   #3
FL71C10
And I thought cunifers were those trees with the pine cones!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-11-2011, 09:53 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Cunifer brake/fuel line kit (Easy to bend and flare and don't rust)
If I bought one of these kits what else would I need? I have a bender and flare tool already and im needing breaks asap..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-11-2011, 10:12 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
I am honestly not sure. It comes with two misc bags of fittings (listed out) but it's a universal style kit...not specific for our trucks. But I was going to use it for my project and as I got it bent order any other necessary fittings before I flared it.
Old 03-12-2011, 09:55 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 03-13-2011, 01:52 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 03-15-2011, 01:13 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 03-17-2011, 03:30 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
fuel, brake, or power steering lines......
Old 03-21-2011, 11:59 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 03-27-2011, 11:51 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
ttt....new parts cheaper than you can buy them and ready to ship!!!
Old 03-28-2011, 12:01 AM   #12
classicchev
classicchev's Avatar
The same shipped to me???
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 03-28-2011, 12:06 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
Sure, I can do that. You guys shouldn't always get burned on shipping I've found USPS isn't too bad...Probably 10-15 extra shipping.
pm sent with payment info
Old 03-28-2011, 08:31 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
still available as of now...
