Old 03-11-2011, 04:50 AM   #1
hollywood763
hollywood763's Avatar
Transmission question
The transmission in my 66 3/4 ton truck is a 4sp with a granny low, and I'm replacing that transmission with another 4sp granny low that's out of a 66 half ton.
will this swap strait across or is there a difference between the half ton trannys and 3/4 ton trannys to where there has to be some modifications made?
I found this transmission on craigslist and I don't want to bother with buying it unless it's an easy swap.
thanks.
hollywood763 is offline   Reply With Quote
Old 03-11-2011, 07:23 AM   #2
blackedoutharley
Re: Transmission question
Provided that you're dealing with both transmissions being SM420's (reverse is towards the driver and down is easiest way to tell) it is a straight swap. The '66 trans may have a provision for back up lights but otherwise they should be the same.
Don't forget to drain and fill with fresh gear oil.
blackedoutharley is offline   Reply With Quote
Old 03-11-2011, 01:29 PM   #3
jarkill
jarkill's Avatar
If the half ton your getting it out of is a short box, double check the U joint size on the tail shaft. It may be different. Mine was
63 C20 Fleetside LWB
jarkill is offline   Reply With Quote
Old 03-11-2011, 02:15 PM   #4
padresag
it is a different style of yoke, depending on whether or not that it is a one piece d/shaft or 2 piece. being as there is no s/bed 3/4t they do not have a 1 piece d/shaft
ron
padresag is offline   Reply With Quote
Old 03-12-2011, 02:37 PM   #5
hollywood763
The Transmission came out of a 1966 short bed stepside.
Could I switch the yoke out of the transmission that's in my truck now into the other transmission?
