Old 03-11-2011, 08:01 AM   #1
knottyrich
77' c10, coil spring spacers?
hey ya'll new guy here, i just got this c10 77' and its 2wd. i am having a hard time find a coil spring spacer, or a bigger coil for the front. i want it to sit level. probly end up lower rear (real easy) but i'd MUCH RATHER lift front 1.5-2". i saw in my lmc catalog they had a heavy duty coil for a truck w/ 454? since i got a 350 maybe that would raise it a bit? seems to me coil springs can't be in that many different sizes (diameter) ? thoughts? thnx
knottyrich is offline   Reply With Quote
Old 03-31-2012, 05:44 PM   #2
68 GMC step long
68 GMC step long's Avatar
Re: 77' c10, coil spring spacers?
I'm working on an 80 C-10 and the customer is worried about the ride. I couldn’t find any plain polyurethane spacers that go under or over the coil so I took a spacer that you wind into the spring and cut it in half to get two ½ inch spacers that will just go under the spring when I put the new coils in. I'll probably put them in Monday and ill post the height difference.
68 GMC step long is offline   Reply With Quote
Old 03-31-2012, 07:51 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
http://www.oreillyauto.com/site/c/de...0&keyword=6454
I put them on my 87 and it leveled it. Actually almost gives it a 4x4 stance.
If you'll go to O'Reillys site and put your vehicle year/make/model in and then search Coil Springs, you'll see those are listed as the "Heavy Duty" ones.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
