Old 03-11-2011, 09:44 AM   #1
rex01atv
Anybody running 3'' belltech spindalls on 67-72???
I have a 72 with beltech spindalls I noticed the tie rods didnt fit the holes in the spindall. Has anybody had this problem??? I bought ends frome a 88 chevy but I dont think they are seated correctly. Any thoughts would be good.
rex01atv is offline   Reply With Quote
Old 03-11-2011, 11:02 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Anybody running 3'' belltech spindalls on 67-72???
What year is your truck? Depending on the inners, you may need either adapter sleeves or new outers from a 73-87, or both.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-11-2011, 03:13 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What year Belltech spindles?
The ball joint and tie rod break down is as follows:
65-70
71-72
73-87
If you have 73-87 spindles on your 72 truck,... you will need to change the upper balljoint and outer tie rod end.
Keith
Convert to disc brakes.
Old 03-11-2011, 05:59 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Doh! Missed the '72 part in the OP This is the answer...
-Chris
