gauge wiring
First problem
OK, I thought I was going to have this thing nailed. I had all the wiring figured out. The green wire went to the temp sender,the blue wire to the oil sender the brown wire was still hooked to the alternator for the volt gauge and the tan wire to the fuel tank. The senders for the oil and temp are new, the fuel is still working ( I believe ) but the gauges for the temp, oil max out as soon as I turn the key on. The volt gauge still does not move. I used a test light and have power from the temp gauge wire (bright light on the test light). The oil sender wire has power but the test light is dim. The volt gauge I dont know what to say, there is power going to it but the gauge does not move. Second Problem Then the POWER DISTRIBUTION BLOCK. I do not have the buss bar in between the two terminals, therefore I put an in-line fuse (10amp) and connected them with the fuse link. The red wire from the alternator is hooked to the small pin on the distribution block with the wire that goes back to the blower motor switch. The other wire, I think, powers the gauges (if Im correct) its hooked to the larger pin with the red wire that goes back to the wiring cluster on the fire wall. Well the fuse blows when I mess with the two wire plug on the alternator. If I leave it, it dont blow the fuse. The fuse I am referring to is the fuse link I put between the two terminals on the Distribution block. I un plugged the alternator, the engine was not running, and when I plug it back in, it blows the fuse. I have something wrong here that I thought I had all figured out and the only think I got done correctly was the plugs and wires. Truck runs great just no gauges.
2004 Silverado Crewcab (Dark Spiral Gray) |
Re: gauge wiring
Ok I took the WHOLE cluster part, cleaned ALL the contact and hooked it back up. I have an oil gauge now but as soon as I hook up the temp sender wire to the sender, It maxed out. Im thinking the sender might be bad but its new.
The volt gauge, it still wont work. I have power to one side but not the top. and there is another terminal on the other side that does not hook to anything. Fuel gauge is working somebody on another page said something about a ground on the back of the cluster, where would this be. I dont have a ground coming off of the cluster. My only othe question is concerning the junction block, still dont kow for sure that is correct
Moderator
![]() Join Date: Oct 2008
Re: gauge wiring
It sounds like Your connector is pinned incorrectly for your cluster.
You have Dark Green from the Coolant-Temp sender. This is right. According to GM... BLUE (there are 4 blue wires) feed one the indicator lamps. TAN should be from the OIL pressure sender. According to GM... You have the oil pressure sender hooked to the FUEL gauge. PINK is from the FUEL sender. Wire Color Table compiled from the 73-87 wiring diagrams in our sister forum. GM CKT...DESCRIPTION.........WIRE COLOR 8......Cluster Lamps.........GRAY 11.....High Beam Lamp.....LIGHT BLUE 14.....Left Turn..............LIGHT BLUE 15.....Right Turn.............DARK BLUE 25.....Gen Telltale...........BROWN 30.....Fuel Gauge............PINK 31.....Oil Sender.............TAN 33.....Brake Lamp...........TAN/WHITE 35.....Temp Sender.........DK GRN 39.....Ignition Power.......PINK/BLACK 150...Grounds................BLACK 237...Seat Belt Warning...PINK/WHITE 931...Electric Choke........DARK BLUE 939...IGN Generator........ORANGE (idiot light clusters only) |
Re: gauge wiring
^ This is correct, and as I mentioned in your other thread, the junction block on the fire wall is not fused between the two terminals. When you put a small fuse inline with the main power feed for the whole truck its gonna blow the fuse. Again like I reccommended in your other post, find or make a jumper for the two terminals, or tie them all to the same terminal, it doesn't matter.
Re: gauge wiring
I dont have a tan wire for the oil sender just the blue, The diagram I have show two differnet dark blues, one for choke heater (i think) and one for oil pressure sender. Also when I ground the blue wire the oil pressure gauge pegs out. The oil pressure is now working , dosmy show very high pressure (about midway below 30 and when I rev it up, it goes almost to 30.
The temp (green ) it pegs when I hook it up to the temp sender. ( might be bad sender but is new ) Fuel gauge works. Volt gauge still does not. I have power to one leg behind the gauge but still just does not move Its very possible this cluster was changed because there has not been anything right on this truck yet. Sorry about the Juction block, was just worried, seems like it should be fused
#6 | |||
Moderator
Re: gauge wiring
You need to verify each pin on your instrument panel plug. Verify every wire position against the tables below. Circuits 8, 11, and 30 are in the same position on both plugs everything else is suspect. IDIOT LIGHT (TELLTALE) INSTRUMENT PLUG WIRE COLORS CKT...DESCRIPTION.........WIRE COLOR 8......Cluster Lamps.........GRAY 11.....High Beam Lamp.....LIGHT GREEN 14.....Left Turn..............LIGHT BLUE 15.....Right Turn.............DARK BLUE 25.....ALT Field..............BROWN (not used on gauge panel) 30.....Fuel Gauge............TAN (PINK 77-80) 31.....Oil Sender.............DARK BLUE 33.....Brake Lamp...........TAN/WHITE 35.....Temp Sender.........DARK GREEN 39.....Ignition Power.......PINK (PINK/BLACK 77-80) 50.....IGN Generator........BROWN to Blower Switch(not used on gauge panel) 150...Grounds................BLACK 237...Seat Belt Warning...PINK/WHITE (YELLOW 77-80) 931...Electric Choke........DARK BLUE 939...IGN Generator........ORANGE to Blower Switch (not used on gauge panel) 1977-1987 GAUGE Plug Pinout by Circuit #s 150........35 14.........150 15..........30 237........39 -----......31 931........39 39..........150 33..........8 30..........11 73-87 IDIOT (Telltale) Panel Plug Pinout 14........150 15........33 39........25 -----....50/939 -----....39 150......35 237......31 ----.....8 30.......11 TAN, LIGHT GREEN, and GRAY should orient the plug for you because they are not moving. You'll be missing a ground and ignition lead for the Volt Gauge. Circuit 50/939 will probably sub for the missing circuit 39 ignition lead. I'd stub off the brown wire from Circuit 25 @ 3" from the plug leaving enough of both pieces to connect them to additional wire. At the plug solder on black wire long enough to reach a good ground this will give you the missing Circuit 150 for the plug. The stub coming from the harness should be Circuit 25 from terminal L on the Delco SI alternator. You need to hook this to an ignition source with an inline resistor... Google "alternator resistance wire". The Pinouts came from http://www.73-87chevytrucks.com/tech...rument_pg1.jpg. Id print the JPG I linked to and the wire-color circuit tables from this message. Quote:
It's the main power junction block. It's actually fused with a high amperage Fusible Link wire at the starter. |
Re: gauge wiring
This truck was peviously a Diesel and converted to gas. If that makes a difference
Re: gauge wiring
This truck is really starting to get on my nerves. I am going to go out and check in a minute but I dont understand something. I have four wires coming out of the firewall for gauges: Tan, Blue, Green, Brown. I see on the diagram where it says tan used for gauges only on the oilsender but I see a Drk Blue for oil pressure switch also
Green I know is for Temp, It pegs when I hook it up Probably bad sender Brown goes to the Alternater but I still cant get the Volt gauge to work Tan I have hooked to the Fuel Gauge and it seems to work, it was hooked up there before and when I put gas in, It went up Besides there was one of the diagrams that showed the tan going to the fuel sender The Dark Blue, I have it hooked to the oil sender, It seems ok, It reads a little low but goes up to almost 30 when I rev as do most GM have low pressure at idle. The blue shows to oil pressure on the same diagram you refer to but with about three other wires and then above that, it shows a tan wire going to the oil sender and say on gauge only clusters. I m trying to follow what you had said about the pins, are you talking about the ones that go to the cluster then there is the ground thing, Any pictures
#9 | ||||||
Moderator
Re: gauge wiring
Your instrument panel plug should look like this. Row A.............Row B BLACK.............DARK GREEN [temp] LIGHT BLUE......BLACK DARK BLUE.......TAN [fuel gauge with tach cluster] PINK/WHITE......PINK ----------........DARK BLUE [oil pressure] DARK BLUE........[volt gauge ignition power] BROWN CKT#50?? PINK................[volt gauge ground] TAN/WHITE.......GRAY* TAN*[fuel]........LIGHT GREEN* Quote:
Let's try to help you get your volt gauge working. There should be three BLACK grounds. The "Instrument Cluster W/O Gauges" harness only has two so you need to add one for the volt gauge. There should be three PINK ignition power wires. Again the "Instrument Cluster W/O Gauges" harness only has two so you need to find or add one for the volt gauge. One BROWN wire is from the alternator. This wire/pin is Circuit #25. Stub the BROWN #25 wire off @ 3in from the plug leaving enough of both pieces to connect them to additional wire. Connect a 3ft chunk of black 18ga wire to the plug stub. Route this wire to a chassis ground. Connect a 3ft chunk of (not black) 18ga wire to the harness stub. Route this wire through a 470 ohm 1/2 watt resistor to an ignition power source. The other BROWN wire in your plug goes to the heater fan plug and fuse panel. This wire/pin is Circuit #50 it should give ignition power to your volt gauge. Last edited by hatzie; 03-27-2011 at 08:16 AM. |
#10 | |
Re: gauge wiring
I have power to one leg of the VOLT gauge. I checked it with the gauge installed but with the clear and black plastic covers off. Its on the right leg as the gauge is mounted inside cluster. There is one on the left side of the gauge that is not attached to anything, just a whole through the white plastic housing. the the top leg, I was figuring to be a ground pole As far as the rest, I think the more I read it the more I am understanding it. Thanks a million for helping me, I may not be able to get back to it till this weekend, but again, thanks for helping me out
Re: gauge wiring
You have found the BROWN Alternator wire Circuit #25. Circuit #25 is not for any gauge and should not be wired to a gauge cluster.
Let's try to help you get your volt gauge working. There should be three BLACK grounds. The "Instrument Cluster W/O Gauges" harness only has two so you need to add one for the volt gauge. There should be three PINK ignition power wires. Again the "Instrument Cluster W/O Gauges" harness only has two so you need to find or add one for the volt gauge. One BROWN wire is from the alternator. This wire/pin is Circuit #25. Stub the BROWN #25 wire off @ 3in from the plug leaving enough of both pieces to connect them to additional wire. Connect a 3ft chunk of black 18ga wire to the plug stub. Route this wire to a chassis ground. Connect a 3ft chunk of (not black) 18ga wire to the harness stub. Route this wire through a 470 ohm 1/2 watt resistor to an ignition power source. The other BROWN wire in your plug goes to the heater fan plug and fuse panel. This wire/pin is Circuit #50 it should give ignition power to your volt gauge.[/QUOTE] i have pmd you Hatzie |
Re: gauge wiring
Ok I went and checked it out. The oil gauge wire ( Drk Blue) is hooked to the oil sender but wondering if this is correct. When I unplug the wire from the sender,the gauge pegs out. When I hooked it back up, it goes back to the normal reading. If thats correct in what it suppose to do, then I am getting closer. Still dont know about the volt gauge though
#13 |
Re: gauge wiring
This thread is from six years ago. Sure hope he has it sorted out by now.
