Old 03-11-2011, 06:34 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
Cutting The Dash For Stereo Tips
I'm gonna cut the dash and put in a Pioneer cd player, Any tips? Any problems. Do I cut the plastic and meta seperate? Does anyone have a link with pics, Thanks
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-11-2011, 07:14 PM   #2
78 Chevyrado
Re: Cutting The Dash For Stereo Tips
Cut and trim up the plastic and metal dash seperately. Cut the hole a little bit too small so you can clean up the hole with a file for smoother results. Fit the sleeve to the plastic bezel, but dont bend the tabs yet and cut the bottom right corner of the sleeve if you have to to fit the bezel. ALSO when you trim for the radio face bezel to fit, trim the radio bezel and NOT the dash bezel, it will look way way better this way.
Onc e you have the hole in the dash bezel like you want it, reinstall the bezel. make sure to install every screw just like you are finished because they can change the hole location. Then slide the sleeve through the hole in the plastic bezel till it touches the metal dash behind and then trace the sleeve to get your cut marks on the metal dash.
Then you're all set.
Remember the radio trim bezel is LARGER then the sleeve so take that into account when placing your hole.
78 Chevyrado is offline   Reply With Quote
Old 03-11-2011, 09:39 PM   #3
78customdeluxe
What I would do is get a bezel from i think 89-91 that had the larger radio in it, that way all you have to do is get one of those kits to install the radio, cut the dash to make it fit, and your good to go. Then if you ever want to you can get a 1 1/2 din radio to put in it and not have to cut any farther...
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
Old 03-12-2011, 12:00 AM   #4
dropd80s
dropd80s's Avatar
I would use this kit from metra. It comes with an extra plate that helps reinforce the radio when mounted, and cuts all the guess work out of where to cut. Also comes with an ABS plate that covers any of the bevels from where the OE radio mounted for a nice clean look. Looks really good when installed. I all ways run a strap from the back of the radio to the bottom of the dash too. This kit with a strap makes for a very sturdy mount. Theres a bunch of these on ebay if you can't find them locally, just search for the Part#.
http://www.metraonline.com/part/87-99-3052
dropd80s is offline   Reply With Quote
Old 03-14-2011, 04:39 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Found this pic while surfin. Not what I want to do but thought it was interesting. Thought Id share.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-14-2011, 06:43 PM   #6
muddnutz
muddnutz's Avatar
Looks cool except that mess of wires sticking out would drive me crazy
muddnutz is offline   Reply With Quote
