Old 03-11-2011, 06:58 PM   #1
rdlackey
How does the HORN work
This is about a 1964 C-10 pickup with a DELUXE STEERING WHEEL (with horn ring). I am trying to:
1. get information on mounting the steering wheel with the HORN COMPONENTS so that the horn will work (does anyone have a installation diagram)?
2. Continuing with #1, what are the actual components (parts) in the steering wheel for the horn ring to work?
Thanks in advance for your replies.
rdlackey is offline   Reply With Quote
Old 03-11-2011, 07:25 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: How does the HORN work
Perhaps these links will help:
http://webhosting.web.com/imagelib/s...309&title=1965 6 Cyl. Engine Compartment w/ Gauges
http://webhosting.web.com/imagelib/s...df8&title=1965 Dash w/ Gauges
http://67-72chevytrucks.com/vboard/s...t=horn+diagram
Old 03-11-2011, 07:49 PM   #3
rdlackey
Thanks...but looking specifically for the steering wheel components and how they assemble for the horn ring. The deluxe steering wheel that I have also was used on the late 50's Chevy Belair and Biscayne.
Old 03-11-2011, 10:26 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I believe post #12 below shows the proper assembly sequence of the horn ring parts:
http://67-72chevytrucks.com/vboard/s...wheel+assembly
And this thread provides related information you may find useful:
Just make sure the spring washer is seated with with dome side up, and the holes align with the hub in the wheel and the nylon spacers, so it doesn't get clamped tight to the hub.
Old 03-12-2011, 04:04 AM   #5
rbar
rbar's Avatar
It works by pressing down on it and then the horn blows. Sorry, I couldn't resist. I took mine apart to repair it and figured I had better take pictures. If this is what you mean, I hope it helps.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 03-12-2011, 04:07 AM   #6
rbar
rbar's Avatar
some more
1965 Chevy swb 383
Old 03-12-2011, 04:13 AM   #7
rbar
rbar's Avatar
And two more
1965 Chevy swb 383
Old 03-12-2011, 06:22 AM   #8
rdlackey
Bingo! Just the images I needed. Any ideas as to where I can get replacement parts for the horn assembly items shown in your steering wheel pictures (spring, insulator, metal ring, etc)?
Also, I am attaching a photo of the back side of my wheel. Notice that it has a "two prong metal something".
1. Should this be there?
2. Am I missing a turn signal cancelling cam, such as shown in your photos that should take the place of the "two prong metal something"?
Thanks again! We are making progress!
Old 03-12-2011, 01:48 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
From the 1963 Chevrolet Truck Shop Manual.
