Old 03-19-2003, 04:07 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
2.5" Exhaust Tubeing to big???
I have 2.25" duals that exit behind the rear axle and I wanted to got to a new exhaust exiting infront of the rear axle at 45 angles. My question is is that would it hurt to make my new exhaust out of 2.5" tubing and have it exit before the rear axle? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 03-19-2003, 04:12 PM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
should be no problem. above that you may run into problems with exhaust velocity on a basically stock 350. otherwise should be ok.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 03-19-2003, 05:08 PM   #3
Ackattack
Ackattack's Avatar
yeah, 2.5 should work fine. IMO 2.25 that isn't mandrel bent is too small.
Ackattack is offline   Reply With Quote
Old 03-19-2003, 05:51 PM   #4
crazy longhorn
Fabricate till you "puke"
actually, the larger the pipe (not mandral bent), but on most exhaust benders will tend to "suck the pipe down " on the bends. 2 1/2 & 3" pipe crush more on the bends than 2 or 2 1/4". 2 1/4" pipe is plenty for a stock 350, & the bends behind the mufflers wont hurt the flow as much as the bends up close to the heat. bigger is louder on the tailpipes, but you can add a set of 3 or 3 1/2x 18" chrome cans to the 2 1/4" pipe & it will sound off ! 3" tail pipes are too loud on my longhorn.......or maybe im getttin too old crazyL
crazy longhorn is offline   Reply With Quote
