Old 03-11-2011, 10:22 PM   #1
ripper70
ripper70's Avatar
Streering Column
Im converting Manual to Auto and am wondering if anyone knows if the Entire Bracket that mounts column,brake,pedal ext. is dif between the 2. It looks like the clutch and brake pedal are 1 assembly. Can use the help guys
ripper70 is offline   Reply With Quote
Old 03-12-2011, 11:49 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Streering Column
Good question....I think they are different, but ttt for ya for some help
by the way to the boards from NC
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-12-2011, 12:06 PM   #3
68anniversary
I converted mine and the only diff was it had just the brake pedal. The whole assembly mounts the same. I heard you can just remove only the clutch pedal, but I bought one for an auto from Randy (teeitup) on the board to save the aggravation.
68anniversary is offline   Reply With Quote
Old 03-12-2011, 12:14 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
I believe you can just remove the clutch pedal off the bracket
Geoff with a G
Old 03-12-2011, 04:40 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Take the clutch rod off, remove the arm from the pedal shaft and the clutch pedal return spring and slide the clutch pedal and shaft out. Be careful with the spring it will eat you alive given the chance... wear safety glasses.
LockDoc
Leon
Old 03-12-2011, 05:17 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Streering Column
I took my clutch out and kept the rest. The only thing is the factory brake pedal is a little off when you look at it now. If you use the factory auto brake pedal it's more to the driver side of the floor. I didn't care though. I have thought about welding a disc brake pedal to it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
