![]() Join Date: May 2002
Decreasing carb size to increase gas mileage?
Hey guys, I've searched to see if I could find the info that I'm looking for, but can't seem to find it. Anyhow, what I want to know is if I change my carb from 750cfm to 600cfm will I gain any mpg's? I have a '69 Longbed with a 350, 700r4, 31" tall tire, and 3.73 gears. I know that switching to EFI would increase mpg, but that just isn't an option at the moment. Any additional knowledge would be appreciated.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
![]() Join Date: Jan 2011
Re: Decreasing carb size to increase gas mileage?
What type of 750 is it? Holley? I'd just consider re-jetting the one I had if I were you. 750 is a little big for a 350 IMO. Is the engine built at all? (cam, headers, etc.? ) I had a built LT1 in a 69 Camaro with a 3310 jetted 70/76 and it was plenty. An out of the box 750 is 72/76 if I am not mistaken. ..
A 600 might make the engine work harder to produce the same power (?) thus eliminating your gas mi savings. Vs. a re-jet and you still get the air flow of a 750.. assuming it's a Holley. Just my .02. Chad
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Is the Current Carb new or old? if it is then a rebuil and rejeting as cc69rat said would definetly. but overcarbing an engine is kinda a thing of the past. David Vizard put an 1150 cfm dominator on a mild 350 and it only lost 7ftlbs and gained 20 hp up top so it depnds on priorities i guess.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) ![]() |
#4 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | ||
I've thought about the 600 causing the engine to work harder, but thought that it might be more efficient with a smaller carb. Quote:
#6 | |
Cruzin
i use quadrajets when i can they do good for mileage and power, and if not i have always run a 600 edelbrock on my 350's seems about perfect for the smaller V-8s
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
If you want a carb that "you dont hafta mess with", go 600 Edelbrock....on a mild build, it will give what you want out of the box. I love tunin.....run a 750 Edel on my 383...not too much to tune. if you really want to tune, that old GM Q-Jet will show you a bunch....not an easy carb to tune(bring you lunch!)crazl
![]() Join Date: Feb 2011
what gas mileage are you getting now? with 3.73 and a 700r4 I think it would be pretty good.
1971 C20 Longhorn Custom Camper |
#10 | ||
That's the thing, I'm not sure. I haven't been able to run a complete tank through yet as I just had the 3.73's installed. Anyhow, before them, I had the 3.08s and was getting about 11.5. I'm thinking that with the new gears that I should be getting about 17. We'll see though.
![]() Join Date: Sep 2001
A Quadrajet is essentially a variable-size carb. It responds and mixes well at all throttle positions. If you want better mileage, teach your right foot to go as easy as possible. Quadrajet economy is very close to EFI. I can get 15+ in my 402 with a Quadrajet when I am easy on the pedal.
its all about the +6 inches
if you end up getting 17 MPG... weld the hood shut and never mess with it again.
I would expect more like 13 to 15 |
#13 |
![]() Join Date: Sep 2010
Location: Oregon, The Beautiful Pacific Northwest (GOD'S country)
How can I figure out what model the Edelbrock is on my small block 400 and which model would run the best on it? The only mods that I know of is the Headmen tube headers and what looks to be Flowmasters or something designed similar and 2-1/2 or 3 inch dual exhaust. Have not measured it, so I am not sure. Thanks!!!
In GOD I Trust ![]() 1969 Chevy CST K/10 SWB (Legs) 1969 Chevy C/20 LWB (Old Gray Mare) Donor 1972 GMC 1500 Sierra Grande (Orange Creamsicle) Sold 1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold 1991 Chevy Silverado Ext Cab (LowBoy) Sold 2008 Harley Davidson Electra Glide (Black Betty) Mark ~ US ARMY VETERAN 2nd ARMORED DIVISION 67th ARMOR |
#14 |
![]() Join Date: May 2012
nightemare: i would thing your tires and rear end would be the place to start, it takes a lot of gas to pull 31" tires, and try at least some where around 340 gears, or 307, i have not seen your truck and how tall it is. so just with what you listed this is what i see....
#15 | |
![]() Join Date: Oct 2009
IF all things are held equal, including your driving habits, you're going to be turning about 20% more rpm in every gear with a 3.73 as you go from point a to point b, so mpg will get worse. That is why ole dollar is recommending a lower (numerical) ratio than the 3.73. It caught my attention that you JUST installed the 3.73s in hopes of increasing economy. |
#16 | ||
WOW, old thread. Still applicable though.
This was all on a 31" tire. I switched to a 29" tire, and that brought the rpms up. My mileage did suffer a little with this, but only a small amount. I would think that with this combination (stock 350, 700R4, and 3.73 gears), and a 600 cfm carb that the mpg's would increase.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 06-07-2012 at 08:56 AM. |
#17 |
That 1901 is a 750cfm carb if I'm not mistaken. I happen to have a 650 (I think, I'll have to check) Edelbrock I am considering selling if you're interested.
It ran great when I took it off my GMC. Pics in the build thread. It was on the truck when I bought it and hasn't been on it long. It is a high dollar carb from Summit.
#18 |
I am a Referee of life.
I would think MPG would be better with the 600 or a 625.Theory(yeh right) is that driveability is better with a vac secondary of smaller CFM due to better vac signal to the carb.If you keep your foot out of it and drive mostly city the secondaries shouldn't open very often as long as the engine is getting the fuel/air it needs.Unfortunately with the specifics of any given vehicle/engine etc.combo you can only go by past experience to determine what to try.That can get more expensive than the fuel to continue with the MPG you currently have.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
