03-12-2011, 01:01 AM | #1 |
"Tilton" starter
Anybody ever use a gear reduction starter with a small block and SM420 trans?
OEM starter bolts to bellhousing rather than to the block. Just curious as to weather I could switch over. |
03-13-2011, 01:05 AM | #2 |
Re: "Tilton" starter
Noboby?
03-13-2011, 01:26 AM | #3 |
60-66 Nut
I don't know anything about the Tilton's, but a regular block mounted GM starter will not work with the older bellhousing like that. Although I have seen guys hack a chunck out of the bellhousing to make them work.
03-13-2011, 05:21 PM | #4 |
Yeah, I don't want to cut up the bellhousing.... wonder if I can install my stock nose cone onto one of the later model oem gear reduction starters.
03-13-2011, 11:26 PM | #5 |
60-66 Nut
The ones I've seen/used are a smaller body, so the older nose won't work.
