Old 03-12-2011, 01:48 AM   #1
duceducenine
duceducenine's Avatar
4spd to automatic
i have a 72 gmc 4spd 4x4
i want to switch to AT
will a 79 AT w/ T.CASE WORK?
duceducenine is offline   Reply With Quote
Old 03-12-2011, 09:55 AM   #2
duallyjams
duallyjams's Avatar
Re: 4spd to automatic
Anything will work if you want it to.
measure the over all length of each set up this will let you know about drive shafts and then there is the auto shifter ( column or floor ) is the auto a np205 ect ect
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-12-2011, 10:05 AM   #3
duceducenine
dont know for sure i havent seen it yet
they want $300 for the combo
Old 03-12-2011, 10:07 AM   #4
duceducenine
i also have to extend the drive shaft anyways
im lengthening the chassis 22"
Old 03-12-2011, 12:55 PM   #5
LANDC
LANDC's Avatar
Find out what they are first. A chain drive t case isn't worth the hassle IMO. Now if you are getting a 400/205, that is definetly worth the hassle.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 03-13-2011, 12:22 PM   #6
duceducenine
what model is the chain drive t case?
Old 03-13-2011, 12:24 PM   #7
Redcap
There are a few. You need to find out what model the trans/transfer case combo is in order to determine if it is a good deal or not. $300 for a TH400/205 isn't a bad deal...same price for a TH350/NP203 is a horrible deal.
Redcap is offline   Reply With Quote
Old 03-14-2011, 10:41 AM   #8
LANDC
LANDC's Avatar
If I am not mistaken, a 208 is chaindrive and the 203 is a full time 4x4 case. A 205 is gear drive and tough as hell. My 205 turns my 44's behind my BB happily. There is a good chance you have a 205 in your truck right now.
Old 03-14-2011, 01:08 PM   #9
duceducenine
my t.c. is c-99404 looks to be s 205
so can i drop the 4 spd and put in the A.T.
or do i need one set up for A.T.?
Old 03-14-2011, 03:36 PM   #10
LANDC
LANDC's Avatar
A 205/TH400 setup was used in K30's for a few years 80-83 roughly I think. I don't know of other applications. I think there may be aftermarket adapters available. From what I have heard the 205/400 adapters are somewhat scarce.
Old 03-14-2011, 04:19 PM   #11
csb#356
It doesn't really matter what automatic transmission you decide to go with, the 205 that you already have will not work the way it is. It would be easiest to get it to bolt up to a th350, because it would not require any modification to the transfer case but you would need to have about $200 worth of adapters. (unless you can find them used of course). To mount it behind a th400 you will have to fully dissasemble the transfer case and put in a new input shaft as well as have the bearing hole bored out, and then you will also need the 205/400 adapter which is nearly impossible to find used unless you search for a long time. Hope you're not getting confused by all these adapter/ input shaft combos but if I had to make a choice honestly I would go with a th350 and the np205, its a fairly strong transmission, and if you're not doing any towing or really extreme wheeling it will work out very good. Actually to be completely honest I would keep your 4 speed, haha, but I guess you're already set on not shifting.
csb#356 is offline   Reply With Quote
Old 03-15-2011, 12:59 PM   #12
duceducenine
i dont mind the 4 spd but nobody else will
be able to drive it.....
Old 03-15-2011, 03:37 PM   #13
LANDC
LANDC's Avatar
Whats the problem then?
Old 03-15-2011, 07:32 PM   #14
coops714x4
coops714x4's Avatar
is this gonna be a daily driver ? if so I would think about a 700R4 they have a lower 1st gear and the overdrive will save wear and tear on your motor AND get better mileage on the highway go look at monster transmissions.com they have the trannys for any application and you can get the adapter from advance adapter I am doing a 71 C/20 4x4 going from the granny 4 to a 700R4 the kit from monster is 2k
coops714x4 is offline   Reply With Quote
Old 03-16-2011, 12:55 AM   #15
duceducenine
its gonna be the work truck so
the go-fer will need to be able
to drive it too.
Old 03-16-2011, 08:27 AM   #16
Dooley
Dooley's Avatar
My stock factory built 1988 V30 2 door regular cab has the T400 and 205 transfercase.
As far as the 203 units, part way through the 78 model year they changed the width and tooth pitch of the gears and chain making it harder for the chain to slip after it's worn,(narrowered from 2.5" to 2" and increased the pitch). The 1979 203 would be a good unit. I have had a couple and they were never a problem.
Dooley is offline   Reply With Quote
Old 03-19-2011, 02:05 PM   #17
Rede
300 for that combo is a steal here...
That same combo 5-6 hours away from me is 800 bucks.
Guess is all depends on the area you live in an how available the parts are.
Rede is offline   Reply With Quote
