Old 03-12-2011, 12:15 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question Hellwig Overloads?
Thinking about finally adding overloads springs to the old K20 and looking at Hellwig Load Pro LP-25 (2500# bolt-ons). My truck is a light-duty K20 with add-a-leafs in the spring pack, but it sags too much with a heavy load. Anyone have comments / complaints about these or anything similar?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-12-2011, 12:24 PM   #2
72supermike
Re: Hellwig Overloads?
I put a set on my truck and they helped. I believe they were the 2500 ones too. I haul big loads of firewood and the truck would sway and be hard to steer but the helper springs helped with that. easy to install and can take them right back off if I don't want them and nothing permanent changed. that's my $.02
72supermike is offline   Reply With Quote
Old 03-13-2011, 12:32 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
:bump: Any other input?
- Mike -
RIP El Jay
Old 09-18-2011, 02:54 AM   #4
OneUglyNerd
I used them on an f350 dually when I was car hauling they worked great although I had the 5000lb set. The truck rode horrible when empty but rode like a caddy with a load. I'd do it again and plan to on my 71 burb 4x4.
OneUglyNerd is offline   Reply With Quote
Old 09-18-2011, 01:16 PM   #5
a2tripp
a2tripp's Avatar
I have em, the ride sucks without a load, but if you load it down its great.
89 GMC V3500
Alaska members check in
a2tripp is offline   Reply With Quote
