Old 03-12-2011, 12:16 PM   #1
trapperjack
trapperjack's Avatar
Photo of factory saddle tank needed.
Had a buddy scrapping a 69, went to pick through the pile. It had 2 saddle tanks. One was toast. One looks ok, maybe. Wondering if this would work on my 67 3/4 4x4 longbed. What I don't get, is it seems to have a return line, a 69 wouldn't have had that would it? Hoped someone here had a photo of one on the ground.
THanks
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 03-12-2011, 12:38 PM   #2
rbagley
rbagley's Avatar
Re: Photo of factory saddle tank needed.
THanks
I'll get one up in about an hour.
rbagley is offline   Reply With Quote
Old 03-12-2011, 01:16 PM   #3
trapperjack
Cool. Thanks. This saddle tank isn't as bad as I thought it might be. holding water at the moment. Can't figure out where it's supposed to mount. May not work on a leaf spring rear?
Old 03-12-2011, 01:58 PM   #4
rbagley
rbagley's Avatar
Here are some. If you need another angle let me know.
Old 03-12-2011, 02:22 PM   #5
trapperjack
Thanks for that. my tank is nothing at all like that. I guess it could have been aftermarket. Thanks for your help.
Old 03-12-2011, 03:15 PM   #6
mr48chev
mr48chev's Avatar
Here is a slightly different style from a different vendor. These tanks were sold as an aftermarket item by dealers and dealer installed after you bought the truck from them. The same as the step bumpers that look almost alike but are different because different vendors in different parts of the country made them and probably sold them regionally.
This came out of a 69 3/4 ton that was originally sold in the Pacific North West.
Old 03-12-2011, 05:46 PM   #7
Livrat
Member #1049
Livrat's Avatar
The tank you have pictured is a factory installed one.. the one in the first picture posted is an aftermarket.. looks to be one manufactured by "travel tanks"
Livrat is offline   Reply With Quote
Old 03-12-2011, 06:51 PM   #8
trapperjack
This is the tank I took off the 69. Must be a later model?
Old 03-12-2011, 11:11 PM   #9
Livrat
Member #1049
Livrat's Avatar
Yes, That is a 73-87 tank..
Old 03-13-2011, 12:54 AM   #10
trapperjack
I'm guessing a sending unit for that tank would read wrong? Not sure it will fit on the 67 anyway, although it's getting a flat bed, so filler would be easy enough.
Old 03-21-2011, 06:44 PM   #11
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
This is the same tank I have factory installed from the Fremont plant.
Not to hi jack but has anyone replaced or refurbished these travel tanks?
Mine are full of rust and would like to see what others may be doing to get these re-done.
Any help is appreciated
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 03-21-2011, 11:22 PM   #12
Livrat
Member #1049
Livrat's Avatar
Ed,
I too had the same issue, I checked into having mine boiled out, the quote was $125.00 and was told that it may not survive due to the rust and crud and we would end up with "pin holes" , It would more that likely need to be coated with a sealer.
So I opted to have it sent out and have it "cloned" only this time made with aluminun instead of sheetmetal..
I got lucky and found an NOS aux pickup/sending unit on ebay..
Old 03-21-2011, 11:51 PM   #13
Ed 72 Sierra Grande
Ed,
Wow that thing is sweet and I'm afraid to a$k!!!
Dropped it today and it needs help. Supposed to have my Radiator guy check it out. I'm hoping for the best. I found one at justtanks for about 7 big ones. Ouch.
Ed F
1972 Sierra Grande
402 bb / Camper
Old 03-22-2011, 09:46 AM   #14
Duncan and son
Ed,
Mark, neat set up... you need to make those and sell them. Mucho dinero I suspect.
Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 03-22-2011, 11:46 AM   #15
Livrat
Member #1049
Livrat's Avatar
Paul
Paul, I had pondered on having more made and selling them.. But I really do not want to get into the "parts business" My holdup is I simply do not have the time for marketing, packaging and shipping.
Having one manufactured like the one pictured is not a problem (the aluminum one is a bit different as it does not have the "bump" on the top like the original for a 72 fuel return line).
The biggest issue is finding a factory AC Delco sending unit, (I got lucky and found one on ebay)
I didn't think it was that expensive, the tank was $375 and the sender was $80
Old 07-04-2017, 09:49 PM   #16
OldChevy1954
Curious how much that aluminum saddle tank holds?
OldChevy1954 is offline   Reply With Quote
