03-12-2011, 01:34 PM | #1 |
2002 S10 ZR2 Dash Speaker Questions
The driver's side dash speaker on my 2002 S10 ZR2 has died. I bought a pair of Sony 4x6 speakers that may fit with a little work. I know the wire connection is a push on, and that I can buy adapters so that I don't have to alter the wiring. The main problem is the oem speaker is 10 ohms. The Sony speakers are 4 ohm. Any chance this will work? Has anybody here replaced the oem dash speakers with aftermarkets?
Eddie |
03-12-2011, 02:59 PM | #2 |
#16876
Re: 2002 S10 ZR2 Dash Speaker Questions
Hey Eddie. Im going to move this to the audio section for you. I think you'll get better results over there.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
03-12-2011, 08:29 PM | #3 |
Thanks Sillyoldman. I wasn't sure where to post it.
Eddie |
03-13-2011, 07:55 PM | #4 |
>130dB Moderator
So the factory speaker is 10ohm? or 1ohm?
In either case, that's freakin weird. Factory systems tend to be though. Just form a standpoint of running it in conjunciton with a stock deck, it might drop the ohm load too low and hurt the deck. You could potentially fry the internal amp. Waht I would do at the same time is replace the factory deck with a new unit. Solves all the problems. Otherwise, factory speakers are your best bet to got trhough it without any hassle.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
03-15-2011, 12:36 AM | #5 |
Are you replacing the headunit or keeping the stock one? If you are replacing the stock headunit or have already replaced it then go ahead and replace the speakers. As far you're question about the wiring I know that Crutchfield has wiring adapters so that you do not have to cut your factory speaker wires, check them out to see if they still have them available.
1994 GMC Sonoma, Bagged, Shaved, Custom paint "Lonoma" 1992 Chevy 1500 2wd "old blue" 1995 Saturn SL1 D.D. |
