Old 03-12-2011, 06:11 PM   #1
SRVBLUES64
brake conversion questions
Im starting my front conversion to disc brakes ao I started removing my drum spindles cause Im getting drop spindles how do I remove the bottom portion of the drum spindle from the bottom A frame? this is on a 66 chevy truck lb I beat the crap out of it but to no avail Any help would be great Thanks Jeff in Indy
SRVBLUES64 is offline   Reply With Quote
Old 03-12-2011, 06:13 PM   #2
Greshampiglet
Re: brake conversion questions
Use a Pickle fork you can rent them or buy how ever your budget allows
Greshampiglet is offline   Reply With Quote
Old 03-13-2011, 12:37 AM   #3
Captainfab
60-66 Nut
Did you hit the spindle where the lower balljoint is? Sometimes it takes 3,4,5 or more good hits to break it loose.
