Old 03-12-2011, 09:58 PM   #1
198plus
198plus's Avatar
Couple Questions
What brake line kit do I need to order for my 65 Chevy truck, it has disc brakes and a 1971 12 bolt rear end........I'm getting ready to install my trans cross member, I was going to set my engine angle at 4 degrees...Does that sound right....
198plus is offline   Reply With Quote
Old 03-13-2011, 07:46 PM   #2
198plus
198plus's Avatar
Re: Couple Questions
Bump........
Old 03-13-2011, 07:59 PM   #3
neto
neto's Avatar
Wouldn't it be the same as for the 65 since it's a bolt on? The only difference is the proportioning valve, MC and the lines between them.
neto is offline   Reply With Quote
Old 03-13-2011, 11:43 PM   #4
Captainfab
60-66 Nut
You could get a kit for a '71-'72, but then you would have to have your entire brake system exactly like a '71-'72.
4 degrees sounds about right. Basically you want the carb flange on the intake to be level or slightly down in the rear when at ride height.
