Where can I find Dana 44 front axle parts?
I can find wheel bearings and seals locally but I am looking for the spindle shaft seal and the little seal which fits on the spindle bearing.
I also need the front axle U-joints. Has anyone found a good source for these parts? Thanks |
Re: Where can I find Dana 44 front axle parts?
Any Napa store should have the wheel bearings, the spindle bearing and seals you will probably have to wait on but they have always had them at my local Napa. They should also have the u-jooints in stock
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
![]() Join Date: Mar 2008
Find a local Spicer dealer. Part number 706527X gets you the three seals and new Torrington bearing for inside the hub. Usually on ebay as well. Fits 90% of Dana 44's in the 70's and early 80's. Spicer dealers will have everything else you need as well.
#4 | |
It was way cheaper than Napa. |
#5 | |
God is good!
![]() M
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
#6 | |
I ended up taking my axles to my local drive line shop. They only charge $10 to remove and install the u-joints. I ended up buying there U-joints, they were made int he USA and they were greaseable, might not be as strong but I like the fact they are greaseable. Total job was $70 This was money well spent as removing the u-joints is a PITA. I had to order front hubs since my bearings races just fell into position in one of the hubs, so I bought 2 complete hubs and rotors. NAPA and Carquest has the hubs and rotors as an assembly or individually. I need to remove the inner seals, clean out the tubes and then replace everything. Looks like another weekend project. Part No's I have so far my 72. Axle U-joints; Autozone Gold 1-0297DG, you can find these at other parts houses Axle shaft interior seals: Timken 5131 Spindle Bearings: National B-2110, appears to better quality than the spicer Hub Grease Seal: Timken 442380 Dana 44 Axle Spindle Seal Kit: 706527x (includes Spindle bearing above and 2 grease seals and spacer) Sorry for a little more information than you asked for but maybe it will help someone else. |
The spindle kit is also at NAPA. Part number SBK-1 :big inner seal, small inner seal, thrust washer, torrington bearing, slinger.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
