Old 03-19-2003, 08:34 PM   #1
76bonanza
76bonanza's Avatar
Guage ?
on the 76 with a 350 what is the temp range of the guage (low middle high) I run around half way up when sitting in traffic wondering what temp that is.
Also anyone replace there stock guages with after market ones?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-19-2003, 08:37 PM   #2
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Warm.....hehehehe j/k usually they should be in that area.. YOu could always get a diff gauge that has actual temp readings on it.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-19-2003, 08:45 PM   #3
76bonanza
76bonanza's Avatar
Ya I would love to redo the dash.
1968 c10
lowered 3" 4"
Old 03-20-2003, 12:46 AM   #4
PHOENIX
Its either 195 or 180 if that helps
Stock thermostat is 195 right?
But isnt 180 common for center of gauge?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-20-2003, 12:59 AM   #5
solidaxel
solidaxel's Avatar
Change your thermostat to a known * and check the location of the needle on your gauge when you are in traffic and see that it stays there, you will know where that * thermo. reads on your gauge !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-20-2003, 01:23 AM   #6
PHOENIX
Not a bad idea, but my stock gauge was never accurate enough to actually monitor the temp. It barely moved around. The autometer is all over the place though, its always moving.
Old 03-20-2003, 01:41 AM   #7
82BlackBeast
here's an article on swervin's page where he swapped out the gauges. It took me a minute to find it but its nicely detailed and tells you exactly what he went through to change all his gauges.
swervin's gauge swap
Matt
'82 Chevy SWB
82BlackBeast is offline   Reply With Quote
Old 03-20-2003, 10:23 AM   #8
solidaxel
solidaxel's Avatar
If it is always moving around it sounds like your thermostat is stuck open. Is the sending unit in the cylinder head or in the intake manifold
LS 3 4L70E
Old 03-20-2003, 01:46 PM   #9
PHOENIX
No nothing is stuck open or anything it is working properly. Right when it reaches 195 (which is the thermostat I have) it starts dropping. Back and forth back and forth all day. The autometers are way more accurate gauges and are worth the money.
I dont have an article about my gauge swap, but Ill have some pictures up soon.
