03-19-2003, 08:53 PM | #1 |
4 speed to automatic
Im converting my Blazer from sm465/205 to turbo 350/205..Are my drive shaft lengths going to change??
Does my crossmember position change?? Thanks , Randy
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
03-19-2003, 08:56 PM | #2 |
Resident Curmudgeon
No and no. It is the adapter between tranny and xfer case that makes up any difference in length with this swap.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-19-2003, 09:01 PM | #3 |
Excelent!!! I have fairley new driveshafts and dont want any snags on conversion day..Thanks CPNE.
Randy
03-20-2003, 12:31 AM | #4 |
its all about the +6 inches
Randy, did you scatter the 4 speed?
03-20-2003, 08:30 AM | #5 |
My 350/205 has the same driveshafts as it did when it was a 3-speed/205. The crossmember under the tranny/t-case didn't even move. I just torched out the rivets from the center section of the crossmember and replaced them with bolts when the new tranny/t-case was in.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-20-2003, 06:25 PM | #6 |
Andy, The 4 speed still works good. Im converting to automatic so i can improve my 100 yard dirt drag times. Plus....I'm tired of shiftin'.....Ever since i was 16 all my daily drivers were manual's...It sucks in traffic and i'm always spillin my beer....So .....automatic here i come.
Randy
03-21-2003, 12:34 AM | #7 |
Ahhh, good point. I forgot you actually race that thing in the mud. You gonna install a higher stall verter? I find my 1900 stall is invisable in traffic, but when I nail it she jumps quite a bit harder.
