Old 03-13-2011, 09:38 PM   #1
72gmcshorty
72gmcshorty's Avatar
shock advice please....
2wd blazer. Belltech 3" drop spindles in front. Bags in front and back. What to use for front shocks? I have shock relocators, super trac bar and notch in back. What to use for back?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-14-2011, 02:45 AM   #2
adpostel
New Member
Re: shock advice please....
Great question, I am doing the same exact setup, and wondering what shocks to use. As of right now, I have CPP Nitro drop shocks on my list......Any suggestions. I want the best value ride quality, I can't afford no shockwaves or nothin' like that, but best conventional shock to go with that will maintain a very nice ride quality.....
1968 C10 LWB Project 454/400
http://www.cardomain.com/ride/2417713
adpostel is offline   Reply With Quote
Old 03-14-2011, 09:28 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Ridetech and Porterbuilt both use Monroe shocks on their basic kits. Part number 33033 will work up front. There are a few options out back depending on your setup (blocks, mounts, etc). Try doing a search for Monroe part numbers here- you will find a lot of info from people who have walked this path before.
Best thing to do is go to the Monroe web site, which has a nice catalog with specs on all their shocks, and find the shock that fits your mounting style with the extended/collapsed lengths you need.
Good luck, any more questions, let us know.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-13-2011, 08:05 PM   #4
72gmcshorty
lets say i had a measurement of 8" aired out (bag empty) and 16" raised up (bag full). When i look for a shock would i look for one with 8" and 16" or Would i have to add any inches to my shock measurement to make sure it wouldn't bottom out? i hope that makes sense
1992 Gmc 2wd
Old 04-13-2011, 11:32 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
You want a 'shorter than your measurements' shock collapsed, so in your case, 7 3/4" or less. You will not likely find a shock longer than 16" that compresses that far, so they will limit your lift some. This can be a good thing, as they will act as limit straps for suspension droop...
-Chris
