Old 03-19-2003, 09:15 PM   #1
Blue_71
Bloo
Blue_71's Avatar
3 speed manual to 4 speed manual?
what all do i need to do this? the parts i have are:
all clutch linkages and new clutch/pressure plate
high hump
column converted to 4 speed (did that when i put the 3 speed in the floor)
4 speed shifter
will my 3 speed driveshaft and cross member work? the cross members look identical to me, but i think the driveshaft is going to be too short
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-19-2003, 09:38 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
The xmember should be find because it bolts to the bell housing. The 3 speed has a slip yolk whereas a truck 4 speed does not. You will have to change driveshafts. Beware, a 3/4 ton DS won't fit a 1/2 ton due to rear end differences. There are also different carrier bearings to consider as well. It's easier to go from 3 speed to auto than to 4 speed because of this.
If this is a car 4 speed, then it's a different story altogether.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-19-2003, 09:44 PM   #3
Blue_71
Bloo
Blue_71's Avatar
it's an SM465, i was looking and it looks like the yolk can be changed, but the 3 speed seemed longer, so i didnt think it owuld work... how hard is it to find a SM465/v8 half ton driveshaft front half?
1989 Chevy K2500
Old 03-19-2003, 09:53 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
There are a lot of factors here, carrier bearing mount and location being a big consideration. If it were me, I'd see about having your existing front driveshaft modified rather than trying to locate the correct setup. Fast68 went thru this a year or so ago and never had any success locating the correct setup for what it's worth
Old 03-19-2003, 09:58 PM   #5
Blue_71
Bloo
Blue_71's Avatar
when i measured the 3 speed seemed 5 inches longer, any idea what it would cost to have a driveshaft lengthened that much? i'll call tomarow to get an excact quote.. it looks to me like i can take the yolk off the drivehsft, and then bolt the 4 speed to it with the little "u" clip things it connects with
