Rpm is too high on 67
I have a 67 with a 283 and a 400 trans, when Im on the hwy it sounds like the engine might blow if i give it too much gas, I dont know where there at because I dont have a tach what can I do to bring the rpm's down?
Re: Rpm is too high on 67
taller gearz or taller tires
#3 | |
I have a 72 GMC, V-8, 3:73 Gears and a Turbo 350. I usually run about 2200-2500 RPM's at 55-60 Mph, but I love the sound! ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
Im running rallys with 275 60 15 on all fours, what gears should it have, and what gears should I install? There is a plug on the side of the 400 trans that has two prongs on it, but there is nothing pluged up on it will that affect anything?
#5 | |
It's ok,you are just used to overdrive. Back when these trucks were new people drove the 70 mph speed limit hiways all day long and never gave it a thought. I love the sound. New stuff just drones down the road
![]() Join Date: Jun 2005
Depends on what you are doing with the truck. If it's just a driver, no pulling or hauling, I would put a 3.42 in it. It probably has 3.73's now.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Old Skool Club
![]() Join Date: Jun 2001
That plug on the side should be for the electrical kickdown. Should be a switch near the carburetor that is actuated by the right accelerator movement. However, if the original carb/intake has been changed, there's a real good possibility that it was tossed....as mine was.
I had my valve body modified and then went with the smallest vacuum modulator (black) and I can effectively kick it down when needed, even though it isn't possible when passing someone.....as I would like. I have a LOKAR Hi-Tech switch to install whenever we get around to putting the drivetrain back into the chassis...maybe this summer. But, what you have is what GM built...back in the day. A 700R4 would give you an overdrive, for some $$$.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Even with 3.42's his engine will still be turning about 3200 @ 70 mph with those tires. That 283 shouldn't mide some rpm's though. If mileage is a concern, I would step up to 3.07's, an overdrive trans, or taller tires.
