Old 03-14-2011, 05:45 PM   #1
junkyardjohn
junkyardjohn's Avatar
New (not rebuilt) 4.3 v-6 power plant
This is a new zero mile 96 4.3 vortec. It was a test motor from g.m.. G.m. Put less than 1/2 a shift (4 hours) on it on a dyno. They kept all of the fuel inj. Stuff off of it. Apparently that was what they were testing. Anyway... I got it & put in a new pertronix H.E.I.., a perfomer alum. Intake & a 500 cfm electric choke model carb.(all new) I put on a used serpetine belt set up, used air conditioning compressor (NOT THE ONE IN THE PIC... A STOCK G.M.) & had the alternator rebuilt as a 100 amp one wire setup.(it had no brackets or pullys on it when I got it)kinda went backwords to old school. It has a 4wd oil pan on it. This was for my 72 short fleet "NO HOLDS BARRED- NOTHING BUT THE BEST-MONEY PIT" project, but I'm going in a diesel direction. (& I PAINTED IT ORANGE... ALL CHEVY MOTORS SHOULD BE ORANGE, UNLESS THEY ARE A DIESEL) I need $1500 for it (alot less than I have in it) picked up in somerset kentucky 42501. G.M.s been putting these motors in full sized trucks for years, so I figured it would push my little 72 just fine. Thought I'd give you guys a shot at it before it went on craigs list or ebay. IT'S A WHOLE LOT BETTER DEAL THAN ONE OF THOSE MADE IN MEXICO CRATE MOTORS. Thanks John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-14-2011, 05:47 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: New (not rebuilt) 4.3 v-6 power plant
That's really cool and seems like a deal for someone!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-14-2011, 08:54 PM   #3
junkyardjohn
Back around
junkyardjohn
DON'T RENT U-HAUL
Old 03-14-2011, 11:32 PM   #4
CORSAIR
CORSAIR's Avatar
Great deal and your right all chevy motors should be chevy orange. bump for you
"The Can't Family Lives Across The Street"
CORSAIR is offline   Reply With Quote
Old 03-15-2011, 02:25 PM   #5
junkyardjohn
I've got over $750 just in the new 500 c.f.m. Electric choke Edelbrock carb, Proform billit hei dist, Edelbrock perfomer intake, Taylor plug wires & Bosch platinum plugs, serpentine belt assy., brackets & pullys & ANOTHER $100 just to have the alternator rebuilt as a 100 amp one wire. Parts for this are expensive..... like big block expesive. I pulled the oil pan to check the bearings & crank, & valve covers to inspect the rockers. I didn't scrimp on anything. It would make a great power plant for a 67-72.... except it's bound to get better fuel milliage than a 350. Someone ought to jump. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-16-2011, 02:51 AM   #6
junkyardjohn
I CAN'T BELIEVE NO ONES SNAPPING THIS UP. I'VE DONE THE MATH SEVERAL TIMES, & I'M LOSING PRETTY SUBSTANCIALLY AT $1500. AM I MISSING SOMETHING OBVIOS??? JOHN FREE, NEW EDELBROCK 14" OPEN ELEMENT AIR CLEANER INCLUDED TOO.
junkyardjohn
DON'T RENT U-HAUL
Old 03-16-2011, 05:42 PM   #7
junkyardjohn
Ttt
junkyardjohn
DON'T RENT U-HAUL
Old 03-17-2011, 05:54 PM   #8
junkyardjohn
THIS WOULD MAKE A GREAT MOTOR FOR ANY STREET ROD, NOT JUST OLD PICKUPS. IT'S COMPLETE WITH THE EXCEPTION OF A SERPENTINE BELT, CARB. TO PAN & MANIFOLD TO MANIFOLD. I HAVE TROUBLE BELIEVING SOMEONES NOT SNAPPING THIS UP. TTT ONE LAST TIME & THEN IT GOES ON CRAIGS LIST & EBAY. (AT A HIGHER PRICE I MIGHT ADD) JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-18-2011, 09:32 AM   #9
junkyardjohn
IT TAKE 2 WIRES TO HOOK THIS UP. ONE 12 VOLT HOT, IGNITION TO HEI & ONE FROM THE ALTERNATOR TO THE BATTERY FOR CHARGING. PRETTY DARN SIMPLE. I'LL EVEN PALLETIZE,BOX WITH PLYWOOD, & LOAD IT IF YOU'LL PAY FOR MATERIALS & ARRANGE TRUCK FREIGHT. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-18-2011, 05:01 PM   #10
junkyardjohn
Btt
junkyardjohn
DON'T RENT U-HAUL
Old 03-20-2011, 03:02 PM   #11
junkyardjohn
ttt
junkyardjohn
DON'T RENT U-HAUL
Old 03-22-2011, 07:59 PM   #12
junkyardjohn
364 VIEWS & NOT A SINGLE NIBBLE... I'M BEWILDERED. IT'S NEW HONEST.. THE VALVE COVER & OIL PAN GASKETS ARE REUSABLE, & WE'LL PULL EM OFF FOR INSPECTION WHEN YOU GET HERE. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 04-09-2011, 06:35 PM   #13
junkyardjohn
Ttt
junkyardjohn
DON'T RENT U-HAUL
