Old 03-14-2011, 08:12 PM   #1
modblacksmith
modblacksmith's Avatar
Question Need info on the NV4500 for a swap.
I found what I think is a Nv4500 5speed, but its out of a 2wd. The up side to it is I mite be able to get it for free.
So my question is can you convert it to a 4wd?
Its in a 95-97 Chevy 3500 pickup.
My other question is how hard is it to swap into my 72, its a factory auto truck with a 454, th400 and a np205, so I know I'll need a clutch petal assembly but what else will I need.
I'm going to look threw the forums to see what I can find on my own but any help would be greatly appreciated.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 03-14-2011, 08:35 PM   #2
b454rat
Re: Need info on the NV4500 for a swap.
You can convert it to 4wd, but finding the tailhousing can be tricky. I had one that I was gonna do it to, but couldn't find one. And when I did, they wanted an arm and a leg for it, couple hundred more could have gotten a 4wd front the start.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-14-2011, 08:50 PM   #3
modblacksmith
Do you have to change the out put shaft too or is it a direct swap?
Old 03-14-2011, 09:37 PM   #4
b454rat
Yep. I had the parts wrote down somewhere that needed to be changed, was only 4 pieces. Output shaft, tailhousing, bearings and a nut maybe?? Been a couple years...
Old 03-14-2011, 09:49 PM   #5
modblacksmith
I read a couple forums about it on here and they made it seam really complicated to do. What about hooking up the clutch and the pedal, how difficult will that be?
Old 03-14-2011, 10:19 PM   #6
b454rat
That I don't know about, having got that far on mine yet!!!!
Old 03-14-2011, 10:49 PM   #7
modblacksmith
MrBeast just filled me in on this on my thread, using the hydraulic clutch out of the donor rig and a divorced t-case. sounds a lot cheaper and easier sense I do all the work on this myself due to the lack of fun tokens to have someone else do it.
Old 03-15-2011, 07:57 AM   #8
duallyjams
duallyjams's Avatar
The turbo 400 with the np205 is it the round pattern ?
Did you read this thread http://67-72chevytrucks.com/vboard/s...d.php?t=437451
and this one http://67-72chevytrucks.com/vboard/s...d.php?t=431033
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-15-2011, 11:02 PM   #9
modblacksmith
I have, thanks. Ive just about read every thread I can find on this. Found just about all the parts I need for the conversion for pretty good prices today.
