Old 03-14-2011, 08:43 PM   #1
byates2
byates2's Avatar
67 C-10 New Engine??
So im restoring my chevy pickup, its a c-10 1967 and the original motor in it was a 283 with a 2 speed powerglide. I want to put a 383 stroker motor in it with a 4l60e tranny. How hard would this be to do.
And im trying to decide on a fuel pump. Im thinking of going with the standard 1721 110 gph 6 psi or the victor series 1711 that is 130 gph 13 psi but requires a regulator. Would it be worth it to upgrade to the victor series and get a racing pump???
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 03-14-2011, 09:05 PM   #2
Ends
Re: 67 C-10 New Engine??
SHould be able to find mounts for it to bolt right in only thing i would look into is the length of the tranny you might have to move the cross member if so you will have to figure out a new driveline i put a 95 whipple charged 454 in my 70' with a 4L80e and all i had to do is move my cross member and everything else lined up for me.
LAYDIIREST member
1970 C10 stepside full tube Chassis, supercharged 454 and much more, 95 motor and trans swap, pro street SLAMMED!
1951 Fleetline custom chopped, channeled, narrowed.
Ends is offline   Reply With Quote
Old 03-14-2011, 10:04 PM   #3
oneday
Not sure about your trans,but as far as a fuel pump goes, I used the 1721 because my engine builder recommended it to be sufficient to my purpose and my approx. 400hp. Unless your a racer or require huge fuel,save some money.My thoughts. 1972 short/fleet 350/350 4/4 drop.10 year hobby.
oneday is offline   Reply With Quote
