Old 03-14-2011, 09:23 PM   #1
thebabybrahma
Distributor stock vs. Accel
Pickup coil is bad on my distributor in my 85 GMC, 5 pin module HEI. Buddy has a complete Accel distibutor that he is not using that I can borrow.
Will it matter if it is a 4, 5 or 7 pin module in the Accel?
'85 C-10, with 93 LT-1 & 4L60
1985 GMC, lookin' for its big block motor - SOLD
'72 Chevy C-10 Cheyenne-SOLD
thebabybrahma is offline   Reply With Quote
Old 03-14-2011, 10:48 PM   #2
ray_mcavoy
Re: Distributor stock vs. Accel
Yes, it does make a difference.
I believe the 5-pin module was originally used on applications with ESC (electronic spark control). That system allowed the timing to be retarded based on input from a knock sensor. A distributor with a 4-pin module can be used in place of the 5-pin one but you'll loose the ESC.
Distributors with the 7-pin module were originally used on computer controlled engines. These distributors don't have any mechanical or vacuum advance mechanisms. Timing advance is totally computer controlled so they're not suitable for swapping into non-computer vehicles.
ray_mcavoy is offline   Reply With Quote
