'Burban Legend
![]() Join Date: Apr 2005
Need Double Cardan joint repair kit part #
Does anybody have a good part number for a Double Cardan joint repair kit? I am seeing them for everything BUT 67-72 Chevy trucks. Would like to get it through Advance Auto if I can, but will try anything at this point. Mine is stock 72 Blazer front end. Hate to put this back together without freshening it up. Thanks, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Need Double Cardan joint repair kit part #
Mike, going to move you over to the Blazer guys.
They are great at finding parts like this. |
If you're talking a np205 front output double cardan, the two u-joints are just regular 1310's and I found a new yoke with the centering ball and bearing on Rockauto.com Part # PE607, from Precision. Napa might also have those. PE280 from Precision are the u-joints. 1310 series.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
the boat guy
neapco numbers 70081 greaseable 70081ng non greaseable center kit. Make sure the weld yoke is in perfect condition and have the shaft ballanced. Coming from someone that rebuilds these every day it's really easy to mess this up. If it's not perfect when it's done it won't last a month. I'd deffenetly reccomend taking it to "the guy".
I wouldn't put anything precision makes in my neighbors lawnmower much less something I own. Last edited by brad_man_72; 03-15-2011 at 11:23 AM. Reason: precision rant. |
'Burban Legend
Thanks guys will see what I can find from this info. I can get Neapco through my company, so I will try that first. Any tricks on doing the u joints? Seems like you have to do all 4 cups at the same time. I had ZERO needles left in the back joint, or I probably wouldnt have touched it. Guess I will just take it slow. Driving around like a 2wd at this point. Thanks again.
