Old 03-15-2011, 02:12 AM   #1
SBTork
Garage wrench
SBTork's Avatar
Show me your notches.
I am trying to gather options/opinions on how to notch the rear of my suburban. Don't be shy, I am not looking to criticise, just looking for options. The rear axle has been flipped and I am now looking to remove a few leaves and add an AOL type system to get it down another inch or two but as I sit now I am about an inch and a half or so from touching frame. My plan as of right now is to cut some pipe and weld it in, then box the frame around it, nothing fancy but should be functional. I know the only option to get it on the ground correctly is to cut up the floor and 4 link it, but I am not sure I want that with this one. So please, let me see what you have.......
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-15-2011, 01:42 PM   #2
onedayjake
Re: Show me your notches.
Pics of your Burb please, I'm trying to decide how low to go with mine.
1947 1/2 ton, 5.3, 4L60E, 10 bolt
1974 Jimmy, 4 inch lift, 35" Thornbirds sold
onedayjake is offline   Reply With Quote
Old 03-15-2011, 07:14 PM   #3
justpball
justpball's Avatar
you can kinda see the notch...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-17-2011, 07:51 PM   #4
SBTork
Garage wrench
SBTork's Avatar
thanks justpball. You have tow'd with your set-up too, right? I am just nervous about towing the occasional trailer with a notched frame. I am sure I will be fine, but just nervous.
-Adam
Old 03-18-2011, 10:26 PM   #5
justpball
justpball's Avatar
Yea I have done some light towing, if you box it in it will be stronger then stock.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-19-2011, 12:38 AM   #6
SBTork
Garage wrench
SBTork's Avatar
cool, that's what I was hoping/thinking. Thanks man
-Adam
Old 03-20-2011, 03:25 PM   #7
b.eddy's72
b.eddy's72's Avatar
Hey SBTork I sent you the PM then saw on here that you are facing the same issue that im having. I guess we will search for soultions together.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-20-2011, 09:32 PM   #8
justpball
justpball's Avatar
no prob homie!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-22-2011, 09:49 PM   #9
b.eddy's72
b.eddy's72's Avatar
Hey justpball I have a few questions if you dont mind.
First your ride is friggin tough....i have looked at all the pics like 100 times and my wife even digs it so that says alot about it cause she isnt impressed about cars easily.
what size pipe did you use for your notchesand did you cut and just run the flush with the top of the frame?
how much lift do you get from the bags in the front and rear?
Thanx Bro
Old 03-30-2011, 03:49 PM   #10
Dave C
Dave C's Avatar
should be getting my burb back this week or next and they are doing a small notch for the bags. i'll post up pics when that happens.
i would expect more people to post up and show off their work...
bagged 1989 burb regency conversion
Dave C is offline   Reply With Quote
Old 04-01-2011, 12:52 AM   #11
SBTork
Garage wrench
SBTork's Avatar
that sounds real good, I sure would appriciate it!
And yes, I thought more would've gotten into this too.....
-Adam
Old 04-12-2011, 01:13 PM   #12
Dave C
Dave C's Avatar
talk about a busy shop... they are finally finishing mine up and it's been there for a month and a half :rofl: snapped these pics while at lunch since i was in the area
Old 04-18-2011, 01:14 AM   #13
SBTork
Garage wrench
SBTork's Avatar
awesome man, thanks for the pics. And yes, I am a moron I never even noticed you posted these here, I need to keep up better....
-Adam
