Old 03-15-2011, 02:37 AM   #1
Thadious
S10 Conversion Headers...
Anyone actually use a set of V8 conversion headers on an S10 swap? How well do they fit, any issues?
Just trying to find a set that I don't have to beat the sh*t out of to fit... sigh...
Thanks,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 03-15-2011, 07:02 AM   #2
xpickup
xpickup's Avatar
Re: S10 Conversion Headers...
Thadious, I used them and they fit and no issues. I bought them from Summit. Shannon
xpickup is offline   Reply With Quote
Old 03-15-2011, 07:46 AM   #3
2ndGenRR
2ndGenRR's Avatar
I tried the Patriot Clippster Headers (H8036) on mine and they contacted the inner fender. Not much, so it could have been corrected with a few hammer blows. I decided to go back to manifolds as I'm not dealing with a high hp engine.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 03-15-2011, 09:05 AM   #4
jeffs51chevy
jeffs51chevy's Avatar
Ted,
I too went back to cast manifolds. I found that the v8 conversion headers work, but much like the whole swap, you have to fiddle with it. At least with my engine placement, I needed to move the steering column on the firewall a bit to get the clearances I wanted. The headers would have worked, but my universal joint was just a little too close for me. I'm sure it could have been worked out, but I want to get this thing on the road.
Thanks,
Jeff
jeffs51chevy is offline   Reply With Quote
Old 03-15-2011, 09:16 AM   #5
jeffs51chevy
Ted,
This is from another build thread. He has a buch of photos here: http://s275.photobucket.com/albums/jj310/rhondayou/
I know its a little old, but it might help.
"I did a lot of research in the header department and here is what I found.
I first looked at the S-10 V-8 headers and although these headers would have made navigating the steering linkage from the steering column to the steering box much easier I did not care for the looks of the one, long swooping header tube that allows the steering linkage to travel through it. This type of header would have required a large relief area to be cut out on the drivers side inner fender to allow the tube to clear, and compromising looks for the added function was not worth it.
I then looked at the block hugger (Ram Horn) style. This style came too close to the upper A-Arm bushings on the S-10 chassis and felt that the heat may start melting the bushings out.
Finally, I purchased shortie, Headmen Headers from Summit, Summit part# HED-68600. The driver side header tucks nicely toward the engine block clearing all of the suspension bushings and allowing for a decent navigation of the steering linkage. The steering linkage will require 2 lenghts of steering shaft. 3 U-joints......1 for the steering box, one for the steering column, one to join the 2 steering shafts. The steering linkage will also require a stationary eye-bearing. No cutting or alteration of the driver side inner fender is needed. One of the header tubes on the passenger side does come a little close to the inner fender, and minor alterations may be required to clear it from hitting and/or burning any paint away from the inner fender. Nonetheless, I found these to be the best look, not to mentiong the 3-bolt exhaust flange and 3" exhaust opening."
Jeff
Last edited by jeffs51chevy; 03-15-2011 at 09:21 AM. Reason: no reason - just computer stupid
Old 03-17-2011, 12:28 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
Good to know!
WIDESIDE72 is offline   Reply With Quote
Old 03-17-2011, 11:04 AM   #7
blitz'd
vintage car junkie
blitz'd's Avatar
I hate those s10 headers. Im either going to make some camaro shorties work or run ram horns.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 03-17-2011, 03:43 PM   #8
one wing angel
one wing angel's Avatar
I have personally used them several times on v8 swaps and have had no issues whatsoever. I have used HEDMAN brand shorties exclusively and they have proven to be a pretty good product.....
I can,t say that they add a whole lot of performance benefits , being the short runner design, but they do fit and look decent as opposed to the cast iron stockers John
one wing angel is offline   Reply With Quote
Old 03-18-2011, 02:59 AM   #9
fredscarryall
fredscarryall's Avatar
i tried to install a set of heddman S10 conversion headers. The passanger header fit perfect.the drivers side fit like garbage. almost all the pictures on the internet show you only a side view of the drivers side header. but what they dont show you is a top view. if they showed you a top view you would see one of the tubes on the header stick so far for the steering clearance that you will have to notch a hole in the inner fender for it to fit. i used a tight tuck patriot center dump header #8053. look on the pertrontic.com web sight and check out the patriot pdf catolog page 4. it fit pecfect with my front ifs rack and i did have to modify it in any way.
fredscarryall is offline   Reply With Quote
