shaving gas filler
im looking for the pre formed piece for metal to shave the gas filler on the cab, anyone know ware i can get this?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Re: shaving gas filler
LMC has them cheap
![]() Join Date: Aug 2009
Blayne |
Old Skool Club
![]() Join Date: Jun 2001
Good link to make a favorite....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Jul 2010
Infanti is what I used. fit like a glove..
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
the boat guy
I'm lazy, I made mine. Took like 20 min. Cut a piece of steel a little too large shaped it using a hammer on top of a 2x4. As I got the shape closer I trimmed the piece to fit. Then had a friend do the finish bodywork.
Fabricate till you "puke"
Im not lazy, but I am cheep! there is not 1 damn pc on the last pic that you cant build yourself
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Man of Mini-Talents
A fine piece of garage art!
| | V ![]()
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
www.infantimachine.com
I have them in stock.If there is anything i can help you with let me know.
Gerry |
Old member
I didn't use anything and I payed to have it done. I'm not a body man so it's worth the extra money to have someone that knows what they are doing to do it!
The body guy made the filler peice himself I guess. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Just a car guy
I got one on the way from infiniti! Ordered off ebay.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
