interchange of a van and p/u
I have a 71-c10 p/u with no sway bar 2wd
the junkyard has a early chevy van (70-73)steel grill) the door arm rest are the same, the cranks are the same..(inner doorpanel is metal) it has dual rear wheels, and 1 ton front hubs(2wd) question is, will the front sway bar fit a 71 c-10 the whole engine cradle and a arms look the same.. if not... will a 2wd 73-87 chevy truck one work?? thanks I want to grap before they crush it.. |
Re: interchange of a van and p/u
I don't think the van bar will fit. The vans used a different frame setup. The 73 up will though. You will need to drill some holes.
o.k. thanks
the van swaybar will fit i got one on my c10 panel from a chevy van g20.
there is a pic of it bolted to the frame http://i341.photobucket.com/albums/o...PICT0005-1.jpg |
#5 | |
what/where you get bushings for it..?? |
the last van i messed with the front end was wider than the truck to include the sway bar but this was a 84 chevy van but should not be that different from the 70-73
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
