Old 03-15-2011, 06:52 PM   #1
Flint70step
Flint70step's Avatar
Old Bent Wrench
Just thought i would share the brace that I made for my alt. bracket.I got a slick alt. bracket that put the alt. down by the frame rail.This did two good things imo,first it gave me a better belt angle than the stock set up.Second, it hid the alt down low for a cleaner looking engine bay.The problem is the brackets themselves are a bit thin and the tension of the belt bent them slightly so the alt. pulley was crooked.
Also, when the engine was running,the bracket moved back and forth a bit.I was looking at the bracket and thought to myself ''Hey there should be a brace at the pivot point to stop the bracket from bending or moving'' or somthin like that.After a few minutes of looking for stuff to bend into shape, I found a couple old wrenches that looked to be about the right length.After clamping it in a vice, putting a torch to it, and hammering the crap outta it, I bent a 3/8-7/16 box wrench to 90 degrees on the 3/8 side.The back side of the bend fractured a little so I welded a bead across the gap to make sure it would stay in place
I ground down the 7/16 side to thin it down a bit and found a longer bolt for the motor mount and bolted the 7/16 side to it.Then all it took to bring the alt,bracket back into proper shape was lock washer as a spacer.
Now both my belts are tensioned the same and the bracket assembly is nice and still while the motor is running, and...NO MORE BELT SQUEALL!!!! This is my fist thread,Plz let me know what yall think of my work.Yall be good Flint70step
Flint70step is offline   Reply With Quote
Old 03-15-2011, 06:54 PM   #2
bigguy69
dazed and confused
bigguy69's Avatar
Re: Old Bent Wrench
That is cool!!!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 03-15-2011, 07:22 PM   #3
69sixpackbee
Re: Old Bent Wrench
Innovative....
69sixpackbee is offline   Reply With Quote
Old 03-15-2011, 07:27 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Old Bent Wrench
Great idea, but I would have used a cheaper wrench!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-15-2011, 07:34 PM   #5
FL71C10
Re: Old Bent Wrench
If you get rid of the truck you can turn in the wrench for a new one!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-15-2011, 07:44 PM   #6
truckster
truckster's Avatar
Re: Old Bent Wrench
And if it breaks Sears will replace it for free. They probably won't bend it for you, though.
truckster is offline   Reply With Quote
Old 03-15-2011, 07:48 PM   #7
bajaracing
bajaracing's Avatar
Re: Old Bent Wrench
where there's a will, there's a way..
bajaracing is offline   Reply With Quote
Old 03-15-2011, 07:51 PM   #8
Flint70step
Re: Old Bent Wrench
All credit goes to my chief mechanic, he may be the only person that loves my truck more than I do
Old 03-15-2011, 08:06 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Re: Old Bent Wrench
That's classic. Nice fix.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-15-2011, 08:27 PM   #10
mixermike
mixermike's Avatar
Re: Old Bent Wrench
you got a handsome helper there
mixermike is offline   Reply With Quote
