Old 03-15-2011, 08:37 PM   #1
darush01
Driveshaft
I have a 72 c20 i broke the yoke on the rear section of the 2 peice drive shaft, i need to know what other vehicles might have a drive shaft that will work or what i might have to do to switch to a single drive shaft. If anyone knows you huys will, i thank you in advance for any advice.
darush01 is offline   Reply With Quote
Old 03-15-2011, 09:51 PM   #2
darush01
Re: Driveshaft
Noone?
Old 03-15-2011, 09:58 PM   #3
05crewcab
05crewcab's Avatar
Re: Driveshaft
Driveshafts generally arent plug and play. you'll have to find one from another 67-72 c20 with the same motor/trans/rear end combo. check the 4 sale section here....you might get lucky.
A better bet might just be to have a driveline shop make a new section to replace the damaged one.
Also, I have heard on here that a one-piece shaft will not work with long beds because the crossmember where the carrier used to be doesn't allow enough downward travel for the suspension. someone can refute that though.
good luck!
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 03-15-2011, 11:07 PM   #4
darush01
Re: Driveshaft
I Was afraid of that, i knew that alot of gm parts from alot of years could interchange i was hoping i would get lucky, thanks for the help
Old 03-15-2011, 11:09 PM   #5
darush01
Re: Driveshaft
Oh and if it help i has the factory 350 4spd, idk which one, and i wanna say 4:5? Rear end
