Old 03-15-2011, 10:41 PM   #1
Steve Van Gent
Steve Van Gent's Avatar
Manual Transmission Options?
GUys,
I think I am going 700R4, but I would like to explore transmission options. The truck has the intermediate bell housing rear engine mount, normal clutch setup...Is my only option the T5 chevy S-10? Are these very stong? DOnt I have to punch a new hole in my floorboard for shift tower, since the tower is further back? Are there any threads on this topic? Are there any 4-speeds I should look at, besides the origional granny low version?
Steve Van Gent is offline   Reply With Quote
Old 03-16-2011, 12:26 AM   #2
dan42
dan42's Avatar
Re: Manual Transmission Options?
Lots of options, depending on how much work you want to do. If I was gonna change out my SM 465 (and I'm not) I would go with a modern 6-speed - but you have to fabricate for the hydraulic clutch and electronic speedo. Do a search, there's a lot of info on this.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-16-2011, 12:53 AM   #3
Wrenchbender Ret
The t-5 is the easiest swap. They are not real strong but if you don't abuse them they will stand up. I run one in my 58 with a 350 & it works great. You do have to make a new hole in the floor.
Wrenchbender Ret is offline   Reply With Quote
Old 03-16-2011, 01:39 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
There was a thread on here a while back where the guy used an adapter on his t56 (six speed) that allowed use of the stock bell housing, flywheel, and fork, but he had to change out the clutch disk because of the different spline count. The speedo still has to be sorted out though. I'll see if I can find it.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-16-2011, 01:54 AM   #5
Jacfourteen
Here's the one I was talking about http://67-72chevytrucks.com/vboard/s...t=polished+t56
Old 03-16-2011, 04:04 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
http://www.keislerauto.com/
Did you start a build thread for this truck... I coulnd't find one or any pictures.....
Rich
1972 K5 Blazer CST Click HERE
Old 03-16-2011, 04:07 AM   #7
Beat68CST
Beat68CST's Avatar
NV-4500?
I hear those can be put together.
Beat68CST is offline   Reply With Quote
Old 03-16-2011, 10:52 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Here is a thread where I posted about the ax15 5 speed trans.
http://67-72chevytrucks.com/vboard/s...d.php?t=417079
If you get a trans with the electric speedometer here is a solution for that:
http://67-72chevytrucks.com/vboard/s...d.php?t=421745
LockDoc
Leon
