03-16-2011, 09:17 AM | #1 |
Loose Ball Joint in lower A arm
Hey Guys,
So last night started putting my a-arms back together, well after pressing in both bottom MOOG ball joints, I found one of them I can wiggle loose and actually out of the seated position easily by 1/4" I could actually probably work it out if I really tried. Has anyone else ever experienced this? Any suggestions on a fix with the obvious one being getting a different lower A? |
03-16-2011, 09:27 AM | #2 |
Re: Loose Ball Joint in lower A arm
There's no real way to fix that. You will need a new a arm.
Posted via Mobile Device |
03-16-2011, 10:42 AM | #3 |
Old Skool Club
You didn't use an upper ball joint instead, did you? I don't know for sure that they are differently sized, but looking at my control arms as they laid on the floor....made me think (just now) that maybe there're slightly different in dimensions. I wish they lower ones bolted in like the uppers, but I think the weight of the front of the truck helps them to stay in place......based on how they mount.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-16-2011, 11:13 AM | #4 |
This happens from time to time. So they make oversized ball joints, or ball joints with a knurl on them. Go about halfway down the first post on the link.
http://67-72chevytrucks.com/vboard/s...d.php?t=324144 |
03-16-2011, 11:37 AM | #5 | |
03-16-2011, 11:40 AM | #6 | |
03-16-2011, 12:19 PM | #7 |
It's all in the timing
As ChevLoRay said,I would think the weight of the truck should hold them in place,unless you plan on pulling the front wheels off the ground.If it were me I would weld a small bead around the hole and file it down if need be to get a tight fit.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
03-16-2011, 12:21 PM | #8 |
I've run into the same problem from time to time. Once in a hurry and the hole was on the edge of being tight, I just tack welded the joint in 3 places. Drove it like that for about 7 years until I sold it
03-16-2011, 02:55 PM | #9 |
Old Skool Club
Would really cheeze-off the next guy who expected to replace ball joints and had to put control arms in it...
03-18-2011, 04:47 PM | #10 |
Sounds like the Janky Monster has been crawling around your garage at night... or a past owner was driving your truck around and only doing left turns.. lol
03-18-2011, 05:21 PM | #11 |
Watch out for your cornhole !
A couple of good tack welds will hold it fine. The weight of the truck tends to keep the ball joint seated in the arm.
03-18-2011, 08:36 PM | #12 |
sharp as a marble
I have done like TX FIREFIGHTER has done before, but there is an option. MOOG, NAPA and others make an oversized balljoint to correct this. Here is a part # for a 1972 Chevy C-10 lower ball joint, that is described as " oversized "
MRC 104112 The two or three tac welds will work damn fine |
03-20-2011, 09:51 PM | #13 |
also using an air hammer on the flange on the lower arm before installing the balljoint will tighten the flange up. I also suggest the oversize ones..
