Old 03-16-2011, 03:22 PM   #1
csb#356
Brakes locked up?
I just got my 1974 1/2 ton 4x4 running again and I put it in gear and I had to really give it gas to get it to move and now I've found that the front brakes are locked up pretty darn tight. Its been parked for about a year. Also I have no pressure at the pedal but that might be because the vacuum line isn't hooked up? I didn't think this should make the brakes lock up. I should also add that when I last drove it the right front brake would randomly lock up and almost pull you off the road. (hence why it was parked) haha. So does this mean that my calipers are bad, or master cylinder maybe?
csb#356 is offline   Reply With Quote
Old 03-16-2011, 04:06 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Brakes locked up?
well the way youre talking i would think that wither the calipers or the rubber hoses to them need to be replaced. having been in a similar spot i decided to just change out both as the lines are only like $15 each and with calipers and brake pads i paid less than $125 for everything and i knew the front brakes were completely good after that
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-16-2011, 10:59 PM   #3
csb#356
Hey thanks for the reply, I will try and get some new hoses and see if that takes care of it, if not I'm headed to the junkyard for some calipers. Can't afford brand new ones for a truck that I might only drive through the fields at work this summer a couple times
