Old 03-16-2011, 07:36 PM   #1
BOZO
Old School
BOZO's Avatar
What M/C's will fit Astro hydroboost?
I had my local auto recycling center (junk yard) order me an Astro hydroboost & M/C for my 69. Upon receiving the parts it became obvious that the setup originally came through the firewall at a downward angle which causes the master cylinder reservoir to set at an angle when mounted level in my truck. The hydroboost/MC came from a 1996 GMC Safari. My question is, what master cylinders from other vehicles will bolt up and set properly level for my truck OR what reservoirs can I replace the angled one with? Will an original MC for power disc brakes (71-72) work?
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 03-16-2011, 08:43 PM   #2
stich626
Re: What M/C's will fit Astro hydroboost?
an angle isn't a bad thing, 70-81 f bodys where
stich626 is offline   Reply With Quote
Old 03-16-2011, 10:04 PM   #3
ls1nova71
ls1nova71's Avatar
You need a HB from an older Astro that doesn't angle down, or at least a bracket to make it sit level. Captainfab on here was selling custom made brackets for them, might try him. And for the original master to work you need to make a spacer to go in the hole in the back of the master because the HB uses a shorter rod. Here's how I did mine, page 6 post #105. http://www.ls1tech.com/forums/conver...0-4l80e-6.html
ls1nova71 is offline   Reply With Quote
Old 03-16-2011, 10:33 PM   #4
BOZO
Old School
BOZO's Avatar
Thanks ls1nova71, the adapter plug is just about what i figgered I'd have to do. Either that or come up with a reservoir that sits level on the 96 Astro MC.
Last but not least;
