Old 03-16-2011, 10:32 PM   #1
yunkyarddog
yunkyarddog's Avatar
lwb to swb convertion (gettin all info now means no WTF later!!!)
so little by little i been gathering info on changin my long bed to short so far got how much and where to take off make cuts etc...
one thing i have not seen is wut to do with my drive line (new to this so thats wut im gonna call it) it i do my math right will end up beeing 11 -12 inches to long
sorry guys new member and never had a PU before and like i said the most info i get now the less WTF laters
yunkyarddog is offline   Reply With Quote
Old 03-16-2011, 11:33 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: lwb to swb convertion (gettin all info now means no WTF later!!!)
You will have to shorten the drive shaft. Did you have a one piece drive shaft or two? You should be able to use a one piece drive shaft with the short bed.
Brake lines will be too long and the intermediate emergency brake cable will be too long. You will have to get one for a short bed.
LockDoc
Leon
Old 03-17-2011, 12:57 AM   #3
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here ya go. This build thread covers the conversion from lwb to swb. It was done by a very knowledgable builder on the forum. He is very informative and would answer questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=316300
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-18-2011, 04:02 PM   #4
yunkyarddog
done on to reading
Old 03-18-2011, 04:32 PM   #5
Beat68CST
Beat68CST's Avatar
Be cool like Slick67 and drive a regular bed (:
Beat68CST is offline   Reply With Quote
Old 03-18-2011, 06:08 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
All the cool cats drive long beds...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-18-2011, 06:10 PM   #7
Beat68CST
Beat68CST's Avatar
Gary
^Precisely
Old 03-18-2011, 10:34 PM   #8
treveiger
treveiger's Avatar
Can go a step further and say the real men drive c20 and c30s jk
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-18-2011, 11:42 PM   #9
67/72junkie
If you're a real 67/72 junkie you drive which everyone suits you that day.As for the drive shaft your longbed is two piece.Your drive shaft will depend on your engine trans combo and location.bb swb is two piece. sb swb can be two or one piece, 6cyl swb is one piece.6cyl is shorter that sb.you can install sb on 6cyl frame towers reversed and swapped sides.you can then use 6cyl driveshaft and trans linkage.this will set the engine and trans back about 7'' from stock sb location.you will also need longer 6cyl or 4x4 speedo cable .hei distributor cap will sit 1/4 from firewall with good cab mounts and everything lined up right.truck will ride and handle much better at high speed and will also launch much better out of the hole because of weight transfer.You will need 4x4 fan shroud in this position if not using electric fan.This is my prefered setup.
67/72junkie is offline   Reply With Quote
Old 03-21-2011, 07:24 PM   #10
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hahaha Thanks!!
Old 04-01-2011, 11:34 PM   #11
yunkyarddog
WELL LITTLE CONFUSING BUT I THINK I COULD GET IT
my real question is can i use my driveshaft
(understanding tha i will measure and take it to a shop to get cut welded and balanced)
is it possible or do i have to go tru all said in the quote
as far as i know this is all i have dout on so i can get started
show some luv
